03 corolla trunk build / Testing some sundowns, scores posted.
This is the stock flap, Im going to ruin its life
Marking centers
I need to make a gap for the PCB since they are just a weee bit too big. Should fit flush when done and shouldnt be visible, I hope.
This was tough to cut straight
mostly done
scribe some semi circles
drill hole, insert coping saw
Screw that coping saw crap
And through the magic of interwebs
not perfect. Should be ok
So after cutting the holes, i wanted the edges to be black instead of flat molded in brown color
I had to cut up the single din SMD meter bezel to make mounts for the gauges.
This is what the look like mounted in place
I used the 2 part epoxy to secure them
I dont have enough screws for both my meters so i had to sand down some i found with some tiny hinges i got from the hardware store
And installed, Not Perfect but im not a c&c machine lol.
Next up is to replace the stock cigerette lighter with a Pac Lc1
I took one of the pieces from the cutouts above and am sanding it to flush mount it from behind the stock location
Bit blurry, but you get the idea
and like so
With a hold drilled in it
Just need to do some cleaning now
while i was uploading the last pics, the JVC cam in. So its installed and i think, right out of the box with flat EQ it sounds better than the pioneer did.
Thje menu navigation sucks, but im probably doing something wrong. Cant back up on step in menus, have to start over for each setting. So im sure im doing something wrong. Gonna have to play around a bit.
Anywho. Pics
Anywho. Pics
Yep. as stated before, I have the same unit, and i cannot figure out how to back out of menu navigation without starting completely over from the home screen. sq is amazing for a lower priced unit. I enjoy it very much and am just now tuning it. Out of the box it was excellent.
But What Do I Know?
2003 Chevy Monte Carlo SS 3.8
  • JVC KD-R975BTS
  • Clarion EQS746
  • Kenwood P907PS
  • Ascendant Audio 12" Havoc v.1
  • Ampere Audio 2000.1
  • MB Quart Onyx 800.4
  • XS Power D3400 - Hood
  • XS Power D975 - Trunk
  • Singer 240A
  • Sky High OFC 0 & 4 gauge
  • Kno Knoise Kolossus Deadener
  • Who's Online   1 Member, 0 Anonymous, 671 Guests (See full list)
