There is no difference, sound is air.
haha 2-3 db's yeah right.
Also a speaker exerts the same force in either direction...who told you that most of the pressure comes from the backwave (it mounted normally)
so tell me your opinion on the box tuning, i didn't mean there is going to be a 2 - 3 db gain on the meter
Edited by DeepHittersMagazine
The only reason it affects tuning is because there is SLIGHTLY more airspace inside the box when inverted
As for logan's question... go ahead and try it if u want... just make sure your surround doesn't rub
Head Unit: Pioneer DEH-P6000UB
Sub Amp:American Bass VFL 500.1
Subs: 4 Fi BL 18's
Enclosure:21.5 Cubic foot flat wall tuned to 40 hz
Batteries: 3 Kinetik 2400's in the back, Kinetik 1200 under hood.
Mids & Highs: 4 Kicker DS 6.5 coax in doors, 2 Kicker DS coax in pillars
Highs Amp: Kicker kx250.2, kx100.2
Wire: 4 Runs 1/0 gauge Knukonceptz
You only have to reverse the polarity if you have different mountings.... like 2 inverted and 2 normal.... otherwise they are fighting each other.... if they are all the same it doesn't matter
Subs: 4 Fi BL 18's
No its not. think about it. its partially correct. If you invert a sub and its still firing normal its going to fire into the box and use the vehicle as the "enclosure" thus making the enclosure entirely to large. This will cause the subs to unload and then your shit outta luck. when you reverse the polarity you are still using the enclosure as the enclosure its just firing backwards over the basket instead of forward from the cone.
Some people need a sympathetic pat... on the head...with my hammer
Scientia est Vox
DONT BE AFRAID TO USE THE SEARCH BUTTON!!!
SMD SUPER BUYER/SELLER
You should also check the cone offset....most speakers are offset a little to the front...now I'm only talking about a few millimeters but that shit makes a difference!!! they are designed to play motor toward the rear...but,try it out!!!
The sub moves the same both ways.... it doesn't matter how you do it as long as all cones are moving the same. You are still using the enclosure, just because the motor is out of the box doesn't change anything in regaurds to the box
Subs: 4 Fi BL 18's
  • Who's Online   0 Members, 0 Anonymous, 852 Guests (See full list)
