come on buddy... whats the new number like since you made all the minor changes/major modifications to the loading chamber
DB DRAG PSYCHLONE PRO 156.3 30 SECOND AVERAGE FO MAX AT 26HZ
LEGAL DASH DRIVER DOOR OPEN 158.0@30 HZ
MY BEST SO FAR, HOPEFULLY A 160 COME FEBUARY.
156.9@26hz  158.0@30hz
So I'm adding more to it, that's the reason for the brief absence haha.
So far, I've added Mass to both sides of the wall. And the roof after sunroof was removed. I also moved it up to the B Pilar. Those 3 things took up 5 extra sheets of .75" wood.
What's being done right now, is 2"x1" Steel tubing the back side of the rear of the wall. This will double as bracing, and mounting of the amps and batts. All 3 amps are going in for Sundown.
The next thing being done, is the roof (cont.), we are filling it up with spray foam, and making it look like a finished product.
Next, is the A pilars, we are building them up to support the MDF room to stay Legal in my org (MECA). I'm doing this because adding a stripper pole would move me out of my extreme street class aka Modified 5.
I have a few more changes to made after all this, but this will get me through the year, and that 167 (hopefully).
165db with 237 DC Volts
6 15" SSA Evils
3 HV Taramps T60k @.33
18 XS Power D3400s
Add me on SC, FB, IG, and YT @ Sencheezy
well keep it up vato!!!its looking pretty awesome and i hope you get that 167. that would be crazy... your transmission hates you!
Thanks for keep up brother. Stay tuned for some pics to follow!
6 15" SSA Evils
18 XS Power D3400s
Yes, pics please. I love this build.
  • 3 weeks later...
i cant wait to see how this turns out..plus im currently living in como,ms about an hour from the tn state line ill deff need to hit you up for a demo sometime
Well, long story short, Mike Smiley (my builder) has had my vehicle since the last update which was built by Brandon Otis from Good Vibrations down in Florida. And there was nearly 0% work done since then. I have a lot of ahead of me to get this ready for world finals and point chasing, and I will keep everyone updated.
Here is all the amps I have in my hopefully 167 build. Also to be added is 4 more D3400s.
6 15" SSA Evils
18 XS Power D3400s
Mate this is awesome, and could also help with my lack of alternator options with my car. Just one question, back on page 9 or 10 you had 12 batts running a 2 60k? or was there more hidden somewhere else as you said you were running 18 batts?
Anyway thinks for the inspiration to look outside the square
Edit : Nevermind i just saw the pics at the start that had the other batts under the car..
TEAM DC AUSTRALIA
Since the Mike Smiley Incident, me and a few locals have began the building process for Valerie for World Finals. The first thing we're attaching is the amp rack. Ultimately, we want it out of steel, but because of time, it may be out of wood as a temp setup.
I've also scratched the idea of running 22 agm D3400s. I have now set my eye on Lithium HV. So for World Finals, my goal will remain 165 outlaw with 3 amps and 18 D3400s. Please keep in my mind, no matter how many 60ks I throw in there, based off my battery bank, I can only have 35-45kw.
The below picture is the mock-up.
The below image is for my future power plant.
Screenshot_2016-09-10-18-35-52_zpsrazob1
The below image is of the proposed bank from JY Power. The specs:
27 13.3v cells in series. 396dcv fully charged, 359dcv float.
received_10209087512680929_zpsspnixbvv.j
6 15" SSA Evils
18 XS Power D3400s
So for roughly $10,000 (batts/amps), I will be able to achieve 140kw for 5 seconds. I believe it was at 2,000 life cycles prior to the performance of the batteries taken a hit.
6 15" SSA Evils
18 XS Power D3400s
  • Who's Online   0 Members, 0 Anonymous, 1389 Guests (See full list)
