GS300Cali93 Posted May 1, 2016 Author Report Posted May 1, 2016 I'm telling you. Just in a questioning way. Sorry, it's the way i explain some things. Asking questions makes people think in my experience. You can do the negative to your block as well if you'd like, for ease of mind if nothing else. it won't cause any harm, as some people do that anyways by increasing the big three to the big four and sometimes the big 5. it's just personal preference. I'm content with three. Thanks bro you have always helped me out ok so Last question. If I do the big 3 on my stock alt can I still use the 300amp for the future upgrade
reedal Posted May 1, 2016 Report Posted May 1, 2016 300amp fuse? Is that what you mean? Or wire rated for 300A? If you mean fuse, then yes, you can, as long as it's not rated for more than the wires ampacity for that length of a run. But if you have a smaller fuse available, use it until you get your new alt SMD Tool Map https://www.stevemeadedesigns.com/board/topic/193176-smd-tool-map-new-november-2014/ Build log https://www.stevemeadedesigns.com/board/topic/197217-reeds-03-tahoe-hat-sqaq-singer-xs-shca-cockbox-80prs/?page=32
GS300Cali93 Posted May 1, 2016 Author Report Posted May 1, 2016 300amp fuse? Is that what you mean? Or wire rated for 300A? If you mean fuse, then yes, you can, as long as it's not rated for more than the wires ampacity for that length of a run. But if you have a smaller fuse available, use it until you get your new alt Going to be running 1/0gauge wire length of runs less then 7 feet each And the smaller fuse makes since should I get one closer to the stock alt amp?
reedal Posted May 1, 2016 Report Posted May 1, 2016 Yes, that would be ideal. SMD Tool Map https://www.stevemeadedesigns.com/board/topic/193176-smd-tool-map-new-november-2014/ Build log https://www.stevemeadedesigns.com/board/topic/197217-reeds-03-tahoe-hat-sqaq-singer-xs-shca-cockbox-80prs/?page=32
MotorCityFats13 Posted May 1, 2016 Report Posted May 1, 2016 if you are talking about fusing the charging lead you would need to do a fuse at both ends and since this wire is a short run and out of the way many opt to not fuse this wire.... if this wire gets pinched it has current running from both ends and 1 fuse in 90% of the time the alt will keep throwing power and you still get crispy car
GS300Cali93 Posted May 1, 2016 Author Report Posted May 1, 2016 if you are talking about fusing the charging lead you would need to do a fuse at both ends and since this wire is a short run and out of the way many opt to not fuse this wire.... if this wire gets pinched it has current running from both ends and 1 fuse in 90% of the time the alt will keep throwing power and you still get crispy car So if the + from alt to + battery terminal is less then 7feet I don't need a fuse and if I use one I need to put one close to the alt and closet to the battery?
ShadeTreeMechanic Posted May 1, 2016 Report Posted May 1, 2016 The fuse is only to protect the conductor like if it gets pinched in an accident. If your conductor is 7 feet long and runs along a place that can get crashed into and has a power source on each end then each end needs to be fused. If your battery is next to your alt, then the chances of it getting pinched are lower because in the event of a crash, the battery is crunched and having good terminal covers becomes more important. imho 91 C350 Centurion conversion ( Four Door One Ton Bronco) 250A Alternator (Second Alternator Coming Soon) G65 AGM Up Front / Two G31 AGM in Back Pioneer 80PRS CT Sounds AT125.2 / CT Sounds 6.5 Strato Pro component Front Stage CT Sounds AT125.2 / Lanzar Pro 8" coax w/compression horn tweeter Rear Fill FSD 5000D 1/2 ohm (SoundQubed 7k Coming Soon) Two HDS315 Four Qubes Each 34hz (Two HDC3.118 and New Box Coming Soon)
GS300Cali93 Posted May 1, 2016 Author Report Posted May 1, 2016 The fuse is only to protect the conductor like if it gets pinched in an accident. If your conductor is 7 feet long and runs along a place that can get crashed into and has a power source on each end then each end needs to be fused. If your battery is next to your alt, then the chances of it getting pinched are lower because in the event of a crash, the battery is crunched and having good terminal covers becomes more important. imho For a nice clean. Run its just about 7 feet from alt to battery and my alt is above the engine towards the front of the car
ShadeTreeMechanic Posted May 1, 2016 Report Posted May 1, 2016 Ok so in your situation you would need a fuse at the alternator and a fuse at the battery. The fuses should be rated lower than what the alt is capable of putting out. In the event of a short, the fuse will have to blow. 91 C350 Centurion conversion ( Four Door One Ton Bronco) 250A Alternator (Second Alternator Coming Soon) G65 AGM Up Front / Two G31 AGM in Back Pioneer 80PRS CT Sounds AT125.2 / CT Sounds 6.5 Strato Pro component Front Stage CT Sounds AT125.2 / Lanzar Pro 8" coax w/compression horn tweeter Rear Fill FSD 5000D 1/2 ohm (SoundQubed 7k Coming Soon) Two HDS315 Four Qubes Each 34hz (Two HDC3.118 and New Box Coming Soon)
GS300Cali93 Posted May 2, 2016 Author Report Posted May 2, 2016 Ok so in your situation you would need a fuse at the alternator and a fuse at the battery. The fuses should be rated lower than what the alt is capable of putting out. In the event of a short, the fuse will have to blow. Lower? So if my alt is 300amp should I get a 200 then? And thanks for the help I'm trying to Learn as much as I can got a new question about batteries. If your down to help lol
