Kinetik Power Cel Question
ok im going to let extreme spl use my hc600 this weekend so today i took it out and just ran everything to my amps and i didnt notice any difference :( . i even hooked it back up and just ran my system from that battery so i know it works? is it that the hc600 is to small for my system.
did i post this in the wrong section?
REST IN PARADISE BIG RICH (Sqmonte) never forgotten
Why do you guys ALWAYS dispute on NUMBERS?????
It's such a played out argument, so fucking annoying....
It's 12 fuckin 15's.... It's louder than you... Shut the fuck up...
/Rant
I'm so jealous, it makes me want to club baby seals. That shit gets down HARD!
dont buy from knowledge he will scam you.
http://www.stevemeadedesigns.com/board/topic/30995-official-knowledge-feedback/
correct section, and well does it help your voltage any, have you put a meter on it to see where your voltage sits with and without? thats the only way to really tell.
Scientia est Vox
SMD SUPER BUYER/SELLER
how do i check my voltage? i m not sure
/Rant
get a DMM (digital multi meter) and set it to 20v dc put it on your amps power and ground terminals and check to see what your voltage is with and without the hc600 while your system is playing at normal listening volume. also check it with your headlight on and off and get a reading of what you voltage does.
Scientia est Vox
the hc600 is a smal power cell, what kind of wattage? and wire etc. you may be looking at geting something a little bigger..
i have audiobahn hcx2300 its suppose to be 2400 rms at 2ohm but i dont think thats correct. i had 1/0 wires and now i have 4g wire again (i keep pulling everything out trying to make it better) big 3 the kinetik 600 and a 4ch alpine amp.
/Rant
ok my bro n lay will be here later ill check thanks
/Rant
if it is 2400 watts then you don't have enough reserve with just the hc600. Try a HC2000 or 2400 if you voltage is dropping to or below 12v
  • Who's Online   1 Member, 0 Anonymous, 1647 Guests (See full list)
