1uP Posted May 9, 2016 Report Posted May 9, 2016 I was wondering if it would be possible to run a DC XL 15" @ .7ohm on a Crescendo BC3500D. The amp says its stable @ .5ohm, but i'm not sure if its only stable at the mentioned .5, 1, 2, or 4ohms mentioned on their page. Also, what does the stiffness of the spider on the sub do, and if it would be worth making mine stiff in my situation.
MrSkippyJ Posted May 9, 2016 Report Posted May 9, 2016 Stable is the lowest, anything higher is fine. F150: Stock 2019 Harley Road Glide: Amp: TM400Xad - 4 channel 400 watt Processor: DSR1 Fairing (Front) 6.5s -MMats PA601cx Lid (Rear) 6x9s - TMS69
reedal Posted May 9, 2016 Report Posted May 9, 2016 Spider stiffness dictates more or less mechanical control. Soft spider, less control, stiff spider, more control. With that, a sub with a stiff spider will need more power to move the same as a sub with soft spider on less power. SMD Tool Map https://www.stevemeadedesigns.com/board/topic/193176-smd-tool-map-new-november-2014/ Build log https://www.stevemeadedesigns.com/board/topic/197217-reeds-03-tahoe-hat-sqaq-singer-xs-shca-cockbox-80prs/?page=32
1uP Posted May 9, 2016 Author Report Posted May 9, 2016 Spider stiffness dictates more or less mechanical control. Soft spider, less control, stiff spider, more control. With that, a sub with a stiff spider will need more power to move the same as a sub with soft spider on less power. Ok, do you think making my sub's spider stiffer would be a good idea?
Broke_Audio_Addict Posted May 9, 2016 Report Posted May 9, 2016 That would depend on your intended use of the sub. That being said a lot of people's definition of "music" is a clipped 30 hz sine wave with some 80 IQ knuckle head grunting about committing crimes and his genitals.
1uP Posted May 9, 2016 Author Report Posted May 9, 2016 That would depend on your intended use of the sub. Well, I plan to run it pretty loud and low and about 100-200 watts away from from its limit.
