Stee-Z Posted May 17, 2016 Report Posted May 17, 2016 I'm wanting to build a 4th order for outside/party/ DJ use for an upcoming event, I figured a down firing 4th order would be the way to go to prevent damage to the speakers themselves from ongoing partiers. The only thing is I have no experience with outdoor applications so any input on wha type of box should be used for optimal output that would be amazing and much appreciated. The lvl 3s will be ran off my Crown 2000 unless I decide to build it for my SC 3515. Thanks and I'm open to everything! (4)DD 9918's (2)DC 10k 8 6.5" focals 2 DD SS4 mid amps Audison Bit One processor Jl-cl-rlc line driver iPad in dash Dual Irragi 320a alts 8 batcaps 4000's Second Skin sound deadened
ShadeTreeMechanic Posted May 17, 2016 Report Posted May 17, 2016 I think normally for outside and large venues, people use the "bass bin" or "scoop" type enclosure to project the sound in the direction of the audience. A down firing sub would do something. It just might not be what you are expecting. 91 C350 Centurion conversion ( Four Door One Ton Bronco) 250A Alternator (Second Alternator Coming Soon) G65 AGM Up Front / Two G31 AGM in Back Pioneer 80PRS CT Sounds AT125.2 / CT Sounds 6.5 Strato Pro component Front Stage CT Sounds AT125.2 / Lanzar Pro 8" coax w/compression horn tweeter Rear Fill FSD 5000D 1/2 ohm (SoundQubed 7k Coming Soon) Two HDS315 Four Qubes Each 34hz (Two HDC3.118 and New Box Coming Soon)
Stee-Z Posted May 17, 2016 Author Report Posted May 17, 2016 That's true, I should dig a little deeper into the matter and keep researching. I also wonder if a mock up loading wall would work at all due to it not being enclosed, or maybe that would just hurt the performance outside? (4)DD 9918's (2)DC 10k 8 6.5" focals 2 DD SS4 mid amps Audison Bit One processor Jl-cl-rlc line driver iPad in dash Dual Irragi 320a alts 8 batcaps 4000's Second Skin sound deadened
ToNasty Posted May 17, 2016 Report Posted May 17, 2016 God damn. Thought you were dead ***Super Sellers List***http://www.stevemeadedesigns.com/board/topic/25829-super-sellers-buyers
Stee-Z Posted May 17, 2016 Author Report Posted May 17, 2016 God damn. Thought you were dead Lmao it's been awhile.. Just remembered my password today. (4)DD 9918's (2)DC 10k 8 6.5" focals 2 DD SS4 mid amps Audison Bit One processor Jl-cl-rlc line driver iPad in dash Dual Irragi 320a alts 8 batcaps 4000's Second Skin sound deadened
Triticum Agricolam Posted May 17, 2016 Report Posted May 17, 2016 Almost all your PA subwoofers are either ported or horns, there are plenty of ways to protect a sub without putting it in a bandpass box or down firing it. What size subs are these? I may know of a good PA horn they might work in. "Nothing prevents people from knowing the truth more than the belief they already know it.""Making bass is easy, making music is the hard part."Builds:
Stee-Z Posted May 17, 2016 Author Report Posted May 17, 2016 Almost all your PA subwoofers are either ported or horns, there are plenty of ways to protect a sub without putting it in a bandpass box or down firing it. What size subs are these? I may know of a good PA horn they might work in. They're 15's (4)DD 9918's (2)DC 10k 8 6.5" focals 2 DD SS4 mid amps Audison Bit One processor Jl-cl-rlc line driver iPad in dash Dual Irragi 320a alts 8 batcaps 4000's Second Skin sound deadened
ShadeTreeMechanic Posted May 17, 2016 Report Posted May 17, 2016 I would love to build a big horn. But then I would have to find a place to keep it. 91 C350 Centurion conversion ( Four Door One Ton Bronco) 250A Alternator (Second Alternator Coming Soon) G65 AGM Up Front / Two G31 AGM in Back Pioneer 80PRS CT Sounds AT125.2 / CT Sounds 6.5 Strato Pro component Front Stage CT Sounds AT125.2 / Lanzar Pro 8" coax w/compression horn tweeter Rear Fill FSD 5000D 1/2 ohm (SoundQubed 7k Coming Soon) Two HDS315 Four Qubes Each 34hz (Two HDC3.118 and New Box Coming Soon)
Triticum Agricolam Posted May 17, 2016 Report Posted May 17, 2016 They're 15's Ok, bummer. What I had in mind would work have worked for a pair of 12"s, but not 15"s. I have some other ideas I'll look into as well. "Nothing prevents people from knowing the truth more than the belief they already know it.""Making bass is easy, making music is the hard part."Builds:
Stee-Z Posted May 17, 2016 Author Report Posted May 17, 2016 They're 15'sOk, bummer. What I had in mind would work have worked for a pair of 12"s, but not 15"s. I have some other ideas I'll look into as well. That would be awesome, I greatly appreciate it, thanks man. (4)DD 9918's (2)DC 10k 8 6.5" focals 2 DD SS4 mid amps Audison Bit One processor Jl-cl-rlc line driver iPad in dash Dual Irragi 320a alts 8 batcaps 4000's Second Skin sound deadened
