Some help with this box
ChrisB4
I just got a DSS etho 15 and I need help with a box design. My specs are 16.5h x 35w x 22d, the car is a 2003 Saab 9-3 and I listen to rap, hip-hop,decaf, djsnt etc. power is a Cresendo bc2000 with a 2nd xs power battery in the trunk. I don't meter so I am just looking for a loud daily on music. Any help is appreciated.
Why not as Quentin for this ???
Here is a suggestion, power: to sub rated, amp subsonic filter to 28Hz, minimum port clearance 4 3/4", figure is just an assembly guide:
NOTE: If building outside you need to build a cardboard dummy box to test fit in it's way inside.
Here is a suggestion, power: to sub rated, amp subsonic filter to 28Hz, minimum port clearance 4 3/4", figure is just an assembly guide:NOTE: If building outside you need to build a cardboard dummy box to test fit in it's way inside.
Wow is that really 3ft^3? It seems the width and depth are a little bigger then a 4ft^3 box I have. I may be wrong tho.
Are you accounting for displacements of the port and double baffle? That will bring the volume down to what Joe has provided you.
oh, I see, thanks for beinging that to my attention.
  • Who's Online   0 Members, 0 Anonymous, 11002 Guests (See full list)
