Jhunt94 Posted June 1, 2016 Report Posted June 1, 2016 just throwing some thoughts out there. You said the front and back both drop at the same time, but the back seems to take longer to come back up. I'm going to assume that you have your fluke on the front battery and you are using your Stinger volt meter to watch the rear. Since digital volt meters like that are slower to react, is it possible that both are coming back up in voltage at the same time, but the Stinger is just not reacting as fast? 2007 Ford F-150 Reg. Cab. Flareside250 Mechman AlternatorSky High Car Audio Big 3 XS Power D3400Rockford Fosgate 1/0 amp kitRockford Fosgate T1500-1bdcpRockford Fosgate T400-4DC Audio Lvl 4 12"Rockford Fosgate Punch 6.5" componentRockford Fosgate Punch 6x8Pioneer AVH-P2300DVDSMD Volt Meter
RooTxBeeR Posted June 1, 2016 Author Report Posted June 1, 2016 just throwing some thoughts out there. You said the front and back both drop at the same time, but the back seems to take longer to come back up. I'm going to assume that you have your fluke on the front battery and you are using your Stinger volt meter to watch the rear. Since digital volt meters like that are slower to react, is it possible that both are coming back up in voltage at the same time, but the Stinger is just not reacting as fast? The back doors not come back up at all, that's the problem I'm trying to figure out. The front will drop and immediately be back up, the back will drop and stay at 13v. On 11/20/2012 at 8:54 PM, AMI CUSTOMS said: Turned mine up today at a light, guy next to me his steering wheel started moving and he looked over at me like I was a magician lol. On 5/9/2012 at 8:45 PM, skittlesRgood said: fuck the plating. look at what the main metal used is. you could buy unicorn blood plated terminals but if its just covering up dog shit, whats the point On 4/10/2013 at 12:26 PM, mrd6 said: I'll admit, half way through sanding that fiberglass in the rain and cold while I was all itchy I was definitely starting to question why i was doing this haha Soon To Be '04 Ford Escape US Alternator 280A Hairpin D4800 Under the Hood (6) XP3000's in Rear 1/0 SHCA & XS Power 4 runs to back TORK2 kit from Tony @ CE Auto Supply Pioneer DEH-80PRS DD AW6.5 (2) per door *Tweeter Unkown* DD SS4a & C3d (2) SCV4000 @ .5Ohm (2) 15" Sundown Zv5
Jhunt94 Posted June 1, 2016 Report Posted June 1, 2016 one battery or two? 2007 Ford F-150 Reg. Cab. Flareside250 Mechman AlternatorSky High Car Audio Big 3 XS Power D3400Rockford Fosgate 1/0 amp kitRockford Fosgate T1500-1bdcpRockford Fosgate T400-4DC Audio Lvl 4 12"Rockford Fosgate Punch 6.5" componentRockford Fosgate Punch 6x8Pioneer AVH-P2300DVDSMD Volt Meter
RooTxBeeR Posted June 1, 2016 Author Report Posted June 1, 2016 one battery or two? Just a front battery. I don't plan on putting more batteries in until I exceed what my alt can produce. Which currently I at the very most, with ac going and closing every window while full tilt, to hit 100a of draw. On 11/20/2012 at 8:54 PM, AMI CUSTOMS said: Turned mine up today at a light, guy next to me his steering wheel started moving and he looked over at me like I was a magician lol. On 5/9/2012 at 8:45 PM, skittlesRgood said: fuck the plating. look at what the main metal used is. you could buy unicorn blood plated terminals but if its just covering up dog shit, whats the point On 4/10/2013 at 12:26 PM, mrd6 said: I'll admit, half way through sanding that fiberglass in the rain and cold while I was all itchy I was definitely starting to question why i was doing this haha Soon To Be '04 Ford Escape US Alternator 280A Hairpin D4800 Under the Hood (6) XP3000's in Rear 1/0 SHCA & XS Power 4 runs to back TORK2 kit from Tony @ CE Auto Supply Pioneer DEH-80PRS DD AW6.5 (2) per door *Tweeter Unkown* DD SS4a & C3d (2) SCV4000 @ .5Ohm (2) 15" Sundown Zv5
Jhunt94 Posted June 1, 2016 Report Posted June 1, 2016 I say get two good meters that can do a min/max function, set them up, run full tilt or whatever, then compare the two numbers. If the one from the rear is bad off then you've got a problem somewhere, if there close, then I say screw it and leave it. As everyone has already said, if you've got like .1 difference front to back, don't worry. If you're losing .5v or more, then start checking connections, and testing the voltage drop on the wire. 2007 Ford F-150 Reg. Cab. Flareside250 Mechman AlternatorSky High Car Audio Big 3 XS Power D3400Rockford Fosgate 1/0 amp kitRockford Fosgate T1500-1bdcpRockford Fosgate T400-4DC Audio Lvl 4 12"Rockford Fosgate Punch 6.5" componentRockford Fosgate Punch 6x8Pioneer AVH-P2300DVDSMD Volt Meter
RooTxBeeR Posted June 1, 2016 Author Report Posted June 1, 2016 I say get two good meters that can do a min/max function, set them up, run full tilt or whatever, then compare the two numbers. If the one from the rear is bad off then you've got a problem somewhere, if there close, then I say screw it and leave it. As everyone has already said, if you've got like .1 difference front to back, don't worry. If you're losing .5v or more, then start checking connections, and testing the voltage drop on the wire. If I honestly had a .5 difference max, I wouldn't care. It's just the fact that the current draw is so tiny compared to what can be produced. And there is a whole volt difference, that is what gets me. I will see if I can find someone with a meter like that. I am dead broke for a while, like, long while, months. So hopefully I can find someone with a better, newer meter to get some better testing done. On 11/20/2012 at 8:54 PM, AMI CUSTOMS said: Turned mine up today at a light, guy next to me his steering wheel started moving and he looked over at me like I was a magician lol. On 5/9/2012 at 8:45 PM, skittlesRgood said: fuck the plating. look at what the main metal used is. you could buy unicorn blood plated terminals but if its just covering up dog shit, whats the point On 4/10/2013 at 12:26 PM, mrd6 said: I'll admit, half way through sanding that fiberglass in the rain and cold while I was all itchy I was definitely starting to question why i was doing this haha Soon To Be '04 Ford Escape US Alternator 280A Hairpin D4800 Under the Hood (6) XP3000's in Rear 1/0 SHCA & XS Power 4 runs to back TORK2 kit from Tony @ CE Auto Supply Pioneer DEH-80PRS DD AW6.5 (2) per door *Tweeter Unkown* DD SS4a & C3d (2) SCV4000 @ .5Ohm (2) 15" Sundown Zv5
GorillaFIngeRs Posted June 2, 2016 Report Posted June 2, 2016 If your readings are consistent you don't need to monitor them both simultaneously. Read at the battery with your one "good" meter and use the same one in the back? I would put the negative lead to your equal length negative and see what you get and then check it with your lead on a solid chassis ground in the back. If it voltage comes up just add a small negative bus in your trunk and you'll have both. AQ3500.115" Fi SP41/0 Knuconceptz Power/Ground 1/0 Sky High Big 3 UpgradePioneer AVH-4200NEXXS Power D1200 Underhood Intimidator Gel In Trunk CES 250A Alternator
RooTxBeeR Posted June 2, 2016 Author Report Posted June 2, 2016 If your readings are consistent you don't need to monitor them both simultaneously. Read at the battery with your one "good" meter and use the same one in the back? I would put the negative lead to your equal length negative and see what you get and then check it with your lead on a solid chassis ground in the back. If it voltage comes up just add a small negative bus in your trunk and you'll have both. I had only monitored them both to check for issues. I only have a single one in my car that reads what the amps see. On 11/20/2012 at 8:54 PM, AMI CUSTOMS said: Turned mine up today at a light, guy next to me his steering wheel started moving and he looked over at me like I was a magician lol. On 5/9/2012 at 8:45 PM, skittlesRgood said: fuck the plating. look at what the main metal used is. you could buy unicorn blood plated terminals but if its just covering up dog shit, whats the point On 4/10/2013 at 12:26 PM, mrd6 said: I'll admit, half way through sanding that fiberglass in the rain and cold while I was all itchy I was definitely starting to question why i was doing this haha Soon To Be '04 Ford Escape US Alternator 280A Hairpin D4800 Under the Hood (6) XP3000's in Rear 1/0 SHCA & XS Power 4 runs to back TORK2 kit from Tony @ CE Auto Supply Pioneer DEH-80PRS DD AW6.5 (2) per door *Tweeter Unkown* DD SS4a & C3d (2) SCV4000 @ .5Ohm (2) 15" Sundown Zv5
Broke_Audio_Addict Posted June 2, 2016 Report Posted June 2, 2016 Wait, How are you measuring the voltage? That being said a lot of people's definition of "music" is a clipped 30 hz sine wave with some 80 IQ knuckle head grunting about committing crimes and his genitals.
RooTxBeeR Posted June 2, 2016 Author Report Posted June 2, 2016 Wait, How are you measuring the voltage? The rear amps I have a stinger volt meter wired too which I have checked to see it's still accurate as they can be. To do that measuring, and to compare the front to back, I use a old fluke DMM. On 11/20/2012 at 8:54 PM, AMI CUSTOMS said: Turned mine up today at a light, guy next to me his steering wheel started moving and he looked over at me like I was a magician lol. On 5/9/2012 at 8:45 PM, skittlesRgood said: fuck the plating. look at what the main metal used is. you could buy unicorn blood plated terminals but if its just covering up dog shit, whats the point On 4/10/2013 at 12:26 PM, mrd6 said: I'll admit, half way through sanding that fiberglass in the rain and cold while I was all itchy I was definitely starting to question why i was doing this haha Soon To Be '04 Ford Escape US Alternator 280A Hairpin D4800 Under the Hood (6) XP3000's in Rear 1/0 SHCA & XS Power 4 runs to back TORK2 kit from Tony @ CE Auto Supply Pioneer DEH-80PRS DD AW6.5 (2) per door *Tweeter Unkown* DD SS4a & C3d (2) SCV4000 @ .5Ohm (2) 15" Sundown Zv5
