natemikegray Posted June 17, 2016 Report Share Posted June 17, 2016 I have two of the exact same amps that I plan on running to each individual sub. I only have 1 gain knob (not bass knob, gain knob) that uses a 4 pin mudular wire. I was wondering if I am able to use a wire splitter like a Belkin F8v109 without hurting anything or messing anything up. All help is appreciated. The amps I were referring to are Cadence Ultrashock A7HC. 2001 Tahoe No system. Not even aftermarket headunit. Link to comment Share on other sites More sharing options...
Wasteland_Audio Posted June 17, 2016 Report Share Posted June 17, 2016 DO NOT DO THIS. I looked into this and it can lead to very bad things. just run 2 gain knobs or none at all Link to comment Share on other sites More sharing options...
natemikegray Posted June 17, 2016 Author Report Share Posted June 17, 2016 I only have the one gain knob and it is IMPOSSIBLE to get another one. I was lucky to be able to get the first one. What kind of bad things are we talking about? In retrospect it should work. Both amps are the exact same so what ever signal that is transfered between amps and knob should be the exact same as well. 2001 Tahoe No system. Not even aftermarket headunit. Link to comment Share on other sites More sharing options...
Noel989 Posted June 17, 2016 Report Share Posted June 17, 2016 Get a pac lc1 and a rca splitter which most likely you should already have if you plan to run multiple amps Build Log - http://www.stevemead...-cruiser-el-pt/ Link to comment Share on other sites More sharing options...
natemikegray Posted June 17, 2016 Author Report Share Posted June 17, 2016 Get a pac lc1 and a rca splitter which most likely you should already have if you plan to run multiple amps Thanks. I just got done researching that device and it seams like my best option. Hears a question. I have a line driver and I was wondering if I could hook up my line driver into this and then into both my amps? The reason I ask is because my deck puts out a 2-3v output and since I am running 2 amps I could set my vote to 10 and have it split between the two. Could this work? 2001 Tahoe No system. Not even aftermarket headunit. Link to comment Share on other sites More sharing options...
Jessica Posted June 17, 2016 Report Share Posted June 17, 2016 Both amps will get the same voltage. Even 10 amps would. You can use a line driver if you want but may not need it Rest in peace, walled 87 accord build log 03' Corolla build with AA Mayhem inside. My super random youtube channel and terrible camera work. Wiring comparison by CaptainzPlanetz Wire and fuse guide by Guest SyKo13 Link to comment Share on other sites More sharing options...
Noel989 Posted June 17, 2016 Report Share Posted June 17, 2016 I would skip the line driver Build Log - http://www.stevemead...-cruiser-el-pt/ Link to comment Share on other sites More sharing options...
Karkov Posted June 17, 2016 Report Share Posted June 17, 2016 PAC-LC1 your amps gains prolly go down to 0.2V (just guessing) so if your gain is not all the way down then you do not need a line driver IMO. if your subs share the same chamber please properly gain match your amps or you could cause premature failure of a sub. 2007 Chevy Tahoe (SOLD) 12 ~ FI Audio X series 10" w/BP option 2 ~ DC Audio 5.0K @0.67 3 ~ DC Audio 5.0K @1.0 2 ~ PPI 3 way sets (not installed yet) 1 ~ RF T400-4, 1 ~ RF T600-2, 1 ~ RF T600-4 4 ~ CT Sounds 5.25" Strato comps (rear fill only) 1 ~ XS Power D4800 1 ~ XS Power D3400 8 ~ XS Power XP3000 160 stock alt, Mechman 370 Elite, 185 DC Power 320+ Sq. Ft. Sound Deadener Pioneer AVH-X5500BHS Youtube: https://www.youtube.com/user/knfjdkghjudfhsgkjdhf/videos?sort=dd&view=0&shelf_id=0 Link to comment Share on other sites More sharing options...
