Christian Murace Posted June 20, 2016 Report Posted June 20, 2016 Thanks everyone who has replied to all my posts. But I have come down to one solution. JL Audio CP112-W0v3 as a subwoofer for my room to listen to music (powering it with a plate amp 4 ohm and power rating is well met, also connected to my av so the power won't be an issue) and I have a small-medium sized normal room that's all tiles and double brick walls so I can really hear subwoofers. WHAT DO U GUYS THINK is this good
DLHgn Posted June 20, 2016 Report Posted June 20, 2016 Was this a question or just stating something?
Christian Murace Posted June 20, 2016 Author Report Posted June 20, 2016 Was this a question or just stating something?Wanting people's opinions, didn't state that clearly haha sorry
MrSkippyJ Posted June 20, 2016 Report Posted June 20, 2016 Why not just buy a sub and enclosure designed for home audio? Or buy a driver and build an enclosure since you have an amp. Probably soind a lot better than a prefab car audio sub/enclosure. Probably cheaper too. F150: Stock 2019 Harley Road Glide: Amp: TM400Xad - 4 channel 400 watt Processor: DSR1 Fairing (Front) 6.5s -MMats PA601cx Lid (Rear) 6x9s - TMS69
Christian Murace Posted June 21, 2016 Author Report Posted June 21, 2016 Why not just buy a sub and enclosure designed for home audio? Or buy a driver and build an enclosure since you have an amp. Probably soind a lot better than a prefab car audio sub/enclosure. Probably cheaper too. this subwoofer comes with a hi quality manufacturers box designed specifically for this sub. Just wanted to know of people if there is some tricky stuff like frequency response or whatever it may be that makes it inappropriate for use
MrSkippyJ Posted June 21, 2016 Report Posted June 21, 2016 Designed for use in a car. Probably tuned way to high to get any kind of use in a house. That's my relatively uneducated opinion though. F150: Stock 2019 Harley Road Glide: Amp: TM400Xad - 4 channel 400 watt Processor: DSR1 Fairing (Front) 6.5s -MMats PA601cx Lid (Rear) 6x9s - TMS69
Joe X Posted June 21, 2016 Report Posted June 21, 2016 Why not just buy a sub and enclosure designed for home audio? Or buy a driver and build an enclosure since you have an amp. Probably soind a lot better than a prefab car audio sub/enclosure. Probably cheaper too.this subwoofer comes with a hi quality manufacturers box designed specifically for this sub. Just wanted to know of people if there is some tricky stuff like frequency response or whatever it may be that makes it inappropriate for use In other word it's going to lack low end if used for home audio, don't do it, if you like the sub get it and do a home audio box for it.
Christian Murace Posted June 21, 2016 Author Report Posted June 21, 2016 Designed for use in a car. Probably tuned way to high to get any kind of use in a house. That's my relatively uneducated opinion though. Thanks for feedback , what I have heard from this sub that for its class of wattage it's slow end monster , I'll hhaa to consider all and make a choice
Christian Murace Posted June 21, 2016 Author Report Posted June 21, 2016 Why not just buy a sub and enclosure designed for home audio? Or buy a driver and build an enclosure since you have an amp. Probably soind a lot better than a prefab car audio sub/enclosure. Probably cheaper too.this subwoofer comes with a hi quality manufacturers box designed specifically for this sub. Just wanted to know of people if there is some tricky stuff like frequency response or whatever it may be that makes it inappropriate for use In other word it's going to lack low end if used for home audio, don't do it, if you like the sub get it and do a home audio box for it. just checking now the sub + box enclosure it supposedly goes down to 22 hertz SUPPOSEDLY
MADVIBES Posted June 21, 2016 Report Posted June 21, 2016 build a 3 cubic foot box and tune it to 20 hz for your home use. DB DRAG PSYCHLONE PRO 156.3 30 SECOND AVERAGE FO MAX AT 26HZ LEGAL DASH DRIVER DOOR OPEN 158.0@30 HZ MY BEST SO FAR, HOPEFULLY A 160 COME FEBUARY. 156.9@26hz 158.0@30hz
