Help choosing amp for door speakers
JerryLZ
I'm running (4) RF Punch P1683's.
I would like to get a amp on these speakers finally but I don't know much about mids and highs so thats why I'm here :help:
Preferred brands would be Sundown or RF but I'm open for suggestions.
These call for
  • power range: 6-65 watts RMS (130 watts peak power)
Side note: I remember seeing something awhile back that was basically a harness that made it easy to run your speakers back to your amp without needing to run wire to each door individually (connected to headunit harness) . Is this a viable option for speakers in my power range?
Looks decent, I figured I would need a 4 channel amp since I have 4 speakers so whats the difference between 2 and 4 besides obviously channels? Would I need 2 of these? I know my speakers are 4ohm, just trying to figure out in my head how this would be wired up.
When you run two 4 ohm speakers in parallel you get a 2 ohm load.
You can use a 2 channel amp for all 4 speakers. Front and rear left on the left channel, F & R right on the right channel.
You will not be able to fade from front to rear like this. You need a 4 channel amp to retain the fader control.
Thanks for the input but I think I'm going to avoid ppi again. I was using a 1000.1 for my subs before I upgraded to my new scv2k recently and I had to Dremel off those bars that cover the screw holes and even then the screws were off center from where you could reach with a screw driver so you lose your bite or you strip the screw to hell. If It was Allen keys instead of Philips then maybe not so bad but definitely a odd set up that I'm not willing to deal with again.
those bars are removeable for installation lol.
Kenwood excelon ddx795
 3 370 amp CES alternators (audio side only)
       McLaren dome tweeters                                   Crescendo 6.5 ultra neos
                                                 NVX JAD800.4
                                            4 PA x4 SPL 18's
                     4 Digital Designs m5's at .7 ohms each
        2 K2 80 ah lithiums
                              3 group 31 agms                                       Ledglow million color (12 piece)
2007 Yukon xl
