Garrett Wells Posted June 28, 2016 Report Posted June 28, 2016 I'm planning on building a sealed box for my SSA G-CON 15. Before I plan the box I need to figure out which way a want to face the woofer and where I want to put the box in my trunk. My Jeep is an SUV obviously and therefore doesn't have a separated trunk. From what I gather, my best option is to have the woofer toward the liftgate and very close to the liftgate. It would be most convenient for me to place it flush with the back seats so I have space. It would also be cool to put my driver side back seat down and have the woofer fire toward me, but in another thread I was told that wouldn't sound good unless I had the box sealed off from the space behind it. Also I want to avoid rattling (I plan on getting Dynamat at a later date). Any help will be appreciated, My emphasis is on SQ
ckeeler11 Posted June 28, 2016 Report Posted June 28, 2016 Since its a sealed single woofer set up just build the box and move it around there until it sounds good to you. You can try up, down, sideways, etc... no port to worry about.
Garrett Wells Posted June 28, 2016 Author Report Posted June 28, 2016 Problem is I'm going to build the box with a slanted back to fit flush with my seats, also theres gunna be a terminal cup
Triticum Agricolam Posted June 28, 2016 Report Posted June 28, 2016 You want the sub to near the perimeter of the vehicle. The idea is to minimize and amount of space between where the sound originates and the edge of the cabin where it will reflect. I had a WJ jeep like yours and had a single ported Sundown E-12 in it. Here is a crappy picture of how my setup was: This worked pretty well for me, but if I were to redo it I would have made the box longer to get the port and sub closer to the tail gate. I also probably would have had the sub on the side of the box firing towards the passenger side instead of firing up. "Nothing prevents people from knowing the truth more than the belief they already know it.""Making bass is easy, making music is the hard part."Builds:
Garrett Wells Posted June 28, 2016 Author Report Posted June 28, 2016 Do you think my best bet would be having the sub facing the lift gate and making the box very deep so the sub is like 4-6 inches from the liftgate
Triticum Agricolam Posted June 28, 2016 Report Posted June 28, 2016 I think that would work, but with a 15" sub is the box is going to have to be pretty wide. I would probably face the sub sideways and put it as close to the back of the box near the tailgate as much as practical. How functional you want your cargo area to be also should be a factor is your decision. I don't know if you care about being to put stuff in your vehicle or not. "Nothing prevents people from knowing the truth more than the belief they already know it.""Making bass is easy, making music is the hard part."Builds:
Garrett Wells Posted June 28, 2016 Author Report Posted June 28, 2016 I dont see how putting the sub sideways would be optimal, Also I want as much trunk space is possible
Triticum Agricolam Posted June 29, 2016 Report Posted June 29, 2016 I'm not sure why think having the sub sideways won't work well, care to expand on your reasoning? Putting the sub sideways is going to save you the most trunk space since the box will only have to be a little wider than the sub is deep. If you face it up or back your box will have to be at least 16" wide. How many cubic feet of volume are you shooting for with this box? "Nothing prevents people from knowing the truth more than the belief they already know it.""Making bass is easy, making music is the hard part."Builds:
Garrett Wells Posted June 29, 2016 Author Report Posted June 29, 2016 It seems like I would get weird cancellation and as a result lose SQ and SPL, I'm going for 3 cu feet
notorious97200 Posted June 30, 2016 Report Posted June 30, 2016 It seems like I would get weird cancellation and as a result lose SQ and SPL, I'm going for 3 cu feet 3? That is a lot. But it will work. If you want to save space, try a smaller box. Just build a box and turn it around to find the right spot. Then you can add anything you need. black BMW X1 2.0 l 192 hp OEM head unit, Amplifiers : Audison AP 8.9 with integrated DSP and Ampere Audio 1200. Focal ES 100 K in front doors, and Dayton RS 180 for midbass under the front seats. 2 SSA DEMONS 10" subs, in a sealed box. SecondSkin Damplifier on front doors, and Luxury Liner Pro for the cargo area.
