BoomZoom808 Posted July 1, 2016 Report Posted July 1, 2016 Are you Joining team sealed? Lol 2010 Mazda 3s 2.5L Pioneer DEH-X9600BHS Knu OFC 1/0 SS Platinum AGM / XS Power XP750 Alpine PDX F-4 / Morel Maximo 5 + Coax 5 IA 10.1 / SSA XCON 12
audiofanaticz Posted July 1, 2016 Report Posted July 1, 2016 I build boxes and ship. All my current enclosures are using the SMD speaker terminals, and wire inside the box with 8awg silver tinned ofc wire from Sundown. 2 12s ported > 3 sealed. If you do 3 sealed, you will have to fire them up to have enough clearance to get the box in the trunk. You will also risk breaking the metal holding the trunk latch on the car body from vibration, and those 2 metal prongs with rubber feet that stick out towards the bottom of the lid when the trunk is open. Previous work that I posted here. http://www.stevemeadedesigns.com/board/topic/204163-kicker-l7-15-box-ive-been-working-on/ Here is a dodge charger I did an install on, it use to have 3 sa-12s firing up and ported towards the back, until it broke the metal around the trunk latch multiple times. http://www.stevemeadedesigns.com/board/topic/146201-dodge-charger-10000watts-rms-to-a-pair-of-fi-btl-n3s/?hl=%20audiofanaticz%20%20charger My slow walled truck build that will never be finished due to working on other peoples systems. http://www.stevemeadedesigns.com/board/topic/187149-updated-32015-fanaticz-shows-his-hoe-some-love-finally-spring-is-here-back-to-work/?hl=+audiofanaticz%20+charger A yukon I built. http://www.stevemeadedesigns.com/board/topic/174700-yukon-xl-rockford-fosgate-atomic-sundown-xs-power-sky-high-alpine-digital-designs/ Lots more photos of various boxes on my instagram... https://www.instagram.com/audiofanaticz/
audiofanaticz Posted July 1, 2016 Report Posted July 1, 2016 This box was maxed out in every direction that can slide in a charger trunk. another quarter inch any way it will not fit. And the outcome of the 3 sa12s ran on a saz4500 at .66 iirc It was welded back and grinded smooth, cracked again. Had to get it cut out and put some 1/8inch steel behind it and fine ever since, but now the car is sealed off so it will never have a chance to break again..
Mariothadon Posted July 1, 2016 Author Report Posted July 1, 2016 This box was maxed out in every direction that can slide in a charger trunk. another quarter inch any way it will not fit. And the outcome of the 3 sa12s ran on a saz4500 at .66 iirc It was welded back and grinded smooth, cracked again. Had to get it cut out and put some 1/8inch steel behind it and fine ever since, but now the car is sealed off so it will never have a chance to break again.. I need that box!!!!!! If it will fit a 2013-14 Charger!!!
dsw422 Posted July 1, 2016 Report Posted July 1, 2016 It's a good thing u don't have the older model.. those trunks have a terribly small opening compared to the newer one.. Here's one I built for a single 15 that had to be put together in 2 pieces.. 2014 Ford Focus SE Sedan Factory Sony 10 Speaker Sound System 1994 Ford Bronco Dual head unit (i kno) Sony door speakers Kenwood Rear Speakers Custom Center console in the works. will house an NVX NSW10" https://m.facebook.com/WinnsCustomCarAudio/
Mariothadon Posted July 1, 2016 Author Report Posted July 1, 2016 It's a good thing u don't have the older model.. those trunks have a terribly small opening compared to the newer one.. Here's one I built for a single 15 that had to be put together in 2 pieces.. Yeah thats super small lol
