Emilio Tizzone Posted July 1, 2016 Report Posted July 1, 2016 Good Morning GuysNew to this forum, seeking help for a SQ Setuphave been doing some crazy researching all night and day about the best set up of 6.5 component speakers and 2/4 channel amplifier for my 2004 Holden combo caddyi would ideally like to have 2 set of 6.5 components in the front doors and a high SQ 2/4 channel amp that can run everything with out issues.or my other option is 1 set of 6.5 components in the doors and directly above the back of me a pair of 6x9 boxed with a 2/4 channel amphave been doing heaps of research on 6.5 components and have come up with a couple speakers listed belowwanting to push 125/150 watts/rms each speaker and looking for them to get crazy loud and still maintain good Sound Quality- Hertz HSK 165XL - Hertz HSK 165 - Morel Temp Ultra 602 - Polk Audio MM6501- Rainbow Germanium CS 265.25Has anyone here had experience with these speakers and could guide me the write way?,i dont mind spending $400/500 (AUD) on a set of componentsAlso would like help choosing a good SQ 4 channel amp or even 2x 2 channel amps that will be able to handle 125/150 watts/rms each channel for long periods of time suggestions and help is much appreciated.
Skullz Posted July 1, 2016 Report Posted July 1, 2016 Great quality speakers can handle a lot of power and the ones you have listed will all get loud and sound damn good doing it, but it is one of those things that are more personal than just our recommendation , it really is best to try and find shops that carry what you want to audition to get a better idea on what you like. There are those that like each brand for their own reason which is valid as they have had great success with the brand. You cannot go wrong with any of the brands you listed plus a ton more that have not been listed. 01 Ford focus ZX3 Pioneer AVH-X491BHS PPI PC 4800.2 Morel Maximo 6.5" x2
Carnines Posted July 1, 2016 Report Posted July 1, 2016 http://www.diymobileaudio.com/forum/car-audio-classifieds/280041-bnib-morel-mw4-midbass-midrange-drivers.html Found a good deal
ShadeTreeMechanic Posted July 2, 2016 Report Posted July 2, 2016 They are 4 inch speakers? 91 C350 Centurion conversion ( Four Door One Ton Bronco) 250A Alternator (Second Alternator Coming Soon) G65 AGM Up Front / Two G31 AGM in Back Pioneer 80PRS CT Sounds AT125.2 / CT Sounds 6.5 Strato Pro component Front Stage CT Sounds AT125.2 / Lanzar Pro 8" coax w/compression horn tweeter Rear Fill FSD 5000D 1/2 ohm (SoundQubed 7k Coming Soon) Two HDS315 Four Qubes Each 34hz (Two HDC3.118 and New Box Coming Soon)
Emilio Tizzone Posted July 2, 2016 Author Report Posted July 2, 2016 thanks heaps for the recommendations,i might head down to the shop tomorrow and test them out, im more leaning towards the morel ultras and hertz hi energy tbh. although every dealer has speakers on display running of the head-units, a bit hard to choose with out an amp to hear them at there best.is there any possible recommendations on a 2 or 4 channel amps that can handle 125-50 watts/rms each channel for long periods of time and that offer clean power and SQ.?i had a look at a - JL Audio HD600.4 - but have a couple more options of amps in mind- Precision Power PPI P900.4 - dont know much about these amps ? - ARC Audio XDI 600.4 - heard are good - CT Sounds AT-125.4 / CT Sounds 125.2 - dont know much about these amp ? have seen people recommend them to others - SoundStream p4.800 - dont know much about this amp ? - Rainbow Beat 2 - heard are good - Nakamichi N4 - heard Korean amps are really good feedback or suggestions guys ?Thanks
Emilio Tizzone Posted July 2, 2016 Author Report Posted July 2, 2016 Also forgot this amp - Sundown audio SAX-150.4
Masterbasser Posted July 2, 2016 Report Posted July 2, 2016 I have the nvx jad 800.4 which is same as ppi 900.4 basically. good amps, running each of the 4 channels at 2 ohms, no problems as of yet. it is a class d 4 channel though Kenwood excelon ddx795 3 370 amp CES alternators (audio side only) McLaren dome tweeters Crescendo 6.5 ultra neos NVX JAD800.4 4 PA x4 SPL 18's 4 Digital Designs m5's at .7 ohms each 2 K2 80 ah lithiums 3 group 31 agms Ledglow million color (12 piece) 2007 Yukon xl
Carnines Posted July 2, 2016 Report Posted July 2, 2016 Don't worry too much about the brand of amp, find a reputable brand of amps and have some overhead on power. Invest in a good dsp/eq.
Emilio Tizzone Posted July 2, 2016 Author Report Posted July 2, 2016 I have 2 picks on Components, which one to go for in terms of SQ, Loudness, Power ? HELP PLEASE- Hertz HSK 165 components - Hertz HSK-165XL componentsany suggestions on amps 125/150 watt/rms each channel anyone ?What is the difference with class D and A/B amps ?
