1968 Pontiac Firebird Convertible Build
ok ill take a break to upload more pics to photobucket. i didnt post everything i had but since im on a desktop instead of my cell ill post as many as i can.
I Rock 4 Doors 4 More Whores!
SMD SUPER SELLER
my seller feedback http://www.stevemead...-mama-feedback/
more seller feedback http://www.stevemead...-slaps-yo-mama/
i cleaned the floor inside and under carriage with degreaser, cone wire wheel and acetone prior to spraying it with bedliner to make the sheet metal more dense and to reduce rattle considering the car is missing the cocktail shakers in the rear. the motor is a pontiac 350 h.o with #16 455 sd round port heads. long tube headers. power steering, power brakes and power top. the only body parts not new is the cowl panel and both doors.
SMD SUPER SELLER
so after 3 weeks at sand blast and my new bushings not fitting on the stock a arms i had blasted and coated..... i said F*ck it and bought these
along with new shocks , spindles, brake kit, steering arms. basically its all new. no sense in trying to save a few $$$$. you get what you pay for
ssbc dual piston calipers i got from a buddy i work with. red caliper paint
cant not have drilled slotted rotors
SMD SUPER SELLER
sorry for whoring my thread out. just been busy with work and working on this. for those of you that know me..... still got the 63 ss nova. its got wilwood tilt column dse mini tub. 4 bar rear with qa1 coilovers all the way around. ill post those pics as soon as i can find the thread.
SMD SUPER SELLER
Nice Ride
Hot and busy lately is what its been like the past few weeks. I got my motor and trans pulled to find out they werent rebuilt like the guy i bought it from said. Im alreafy this far so no turning back now. Heads and crank are at the machine shop getting a refresh. Going to hone the cylinders , put a bigger cam and get new seals on the heads. The 1973 #16 heads are threaded studs with big valves. These came on the 455sd and have a 114 cc flow with round exhaust ports. Should breathe well and push somewhere in the 350 + hp range
SMD SUPER SELLER
  • Who's Online   0 Members, 0 Anonymous, 1424 Guests (See full list)
