Skyler Knapp Posted July 6, 2016 Report Posted July 6, 2016 I'm wanting to build my first box. Right now I have two cvxs in a shitty prefab box. I'm getting 2 soundqubed hds212's and would like to build a ported box. Any help would be appreciated. My max dimensions are 35w 16h and 18d but it could go a little deeper if need be I just don't really want it to.
Skyler Knapp Posted July 6, 2016 Author Report Posted July 6, 2016 Hifonics brutus 1600 and 97 Acura CL
ckeeler11 Posted July 7, 2016 Report Posted July 7, 2016 Will need more depth but this is a design i used by Joe X. Joe if i shred improperly let me know. Chris
n8ball2013 Posted July 7, 2016 Report Posted July 7, 2016 Help or a design. Because it looks like you're asking for a design not help. THERE IS NO BUILD LOG! 1998 Chevy Silverado ext cab Alpine CDA-9887 4 Team Fi 15s 2 Ampere Audio TFE 8.0 2 Ampere Audio 150.4 3 Digital Designs CS6.5 component sets Dual Mechman 370XP Elite alternators inbound! 8 XS Power d3400 6 XS power d680 Second Skin Stinger Tsunami Wiring Sky High A Real Voltmeter not a piece of shit stinger.
Skyler Knapp Posted July 7, 2016 Author Report Posted July 7, 2016 Help or a design. Because it looks like you're asking for a design not help. Design my bad.
Joe X Posted July 7, 2016 Report Posted July 7, 2016 I'm wanting to build my first box. Right now I have two cvxs in a shitty prefab box. I'm getting 2 soundqubed hds212's and would like to build a ported box. Any help would be appreciated. My max dimensions are 35w 16h and 18d but it could go a little deeper if need be I just don't really want it to. So here is a suggestion, power: to subs rated, amp subsonic filter to 28Hz, minimum port clearance 5 1/2", figure is just an assembly guide: NOTE: If building outside you need to build a cardboard dummy box to test fit in it's way inside. The box ckeeler11 has posted could also work if you can fit it.
Skyler Knapp Posted July 7, 2016 Author Report Posted July 7, 2016 I'm wanting to build my first box. Right now I have two cvxs in a shitty prefab box. I'm getting 2 soundqubed hds212's and would like to build a ported box. Any help would be appreciated. My max dimensions are 35w 16h and 18d but it could go a little deeper if need be I just don't really want it to. So here is a suggestion, power: to subs rated, amp subsonic filter to 28Hz, minimum port clearance 5 1/2", figure is just an assembly guide: NOTE: If building outside you need to build a cardboard dummy box to test fit in it's way inside. The box ckeeler11 has posted could also work if you can fit it. Thank you so much!
Skyler Knapp Posted July 7, 2016 Author Report Posted July 7, 2016 If I used the same design and specs of the box you just suggested except I do 33w instead of 35w how would that turn out? Just curious as I'd like to keep my amp kind of tucked away. I could always find another place to put my amp if it wouldn't work out.
Joe X Posted July 7, 2016 Report Posted July 7, 2016 I would do the above one and relocate the amp but if you are set to have a 33W box here's a slightly compromised alternative that you could use:
