Mack187Murder Posted July 16, 2016 Report Posted July 16, 2016 So. Ive been busy since my first install of a jl audio 13 w7 and hd 1200 amp. Stock everything else And pioneer Components (fuck jls overpriced garbage. MY OPINION. Never again) I now have - fi sp4 18" sub. -crescendo encore 4500 watt rms amp. -378 amp at1800 rpms 274 amp idle birthsheet mechman billet alternator -2x3300 amp xs power batteries -2/0 gauge 100 copper wiring everywhere. -2xhertz mille 1650.3 woofers. Tweets. Cross -2x cdt audio m6 gold WOOFERer( FUCKING LOVE THESE) -hertz hcdp 1000 watt rms 4 channel -48 square feet of dynamat xtreme on cab floor. Roof and wall -48 square feet sound damp pro on all 4 doors sealed off Ive read all iver the place these subs can eat double what u throw at them but since this a daily driver. And i still plan on keeping my small back seat in the back of my 2012 denali 1500. I settled with 4500 I wanted to build a pirted box 5 to 7 cubes tuned to 25 hz. However. Dont have the time. Money to get one built . Or patients yet to do so. So i was gonna go sealed for now. Easy. Can put together myself. Have it rocking in a week for summer. Will build ported later. I listen to drum and bass. Crunk. Dub. Raggaton beats. The odd fucking dubstep track when my wifes being a cunt. Whhat do u guys suggest for the best sounded sealed box. Any critisicm, knowledge, help is appreciated. Thanks mike .
Mack187Murder Posted July 16, 2016 Author Report Posted July 16, 2016 My trucks not with me brother and im in camp for a month. Im just curious as to what cubic size for the sealed box with the amount of power im throwing at it. .
Mack187Murder Posted July 16, 2016 Author Report Posted July 16, 2016 I wi post pictures as soon as i get back .
Kyblack76 Posted July 16, 2016 Report Posted July 16, 2016 you are the first to ask for a sealed enclosure for a sp4 that ive ever seen. ....... ever.... SMD SUPER SELLER The Burban Build Blazer Build sold Acura trunk build sold
Mack187Murder Posted July 16, 2016 Author Report Posted July 16, 2016 you are the first to ask for a sealed enclosure for a sp4 that ive ever seen. ....... ever.... ok so will it sound like shit. Or does nobody know? Lets look at my options here. Ionly have 5 for sure MAYBE 6 cubic for a ported box. Will that not be enough airpsace or because of the 4500 watts 5 to 6 cube be fine for ported? .
ShadeTreeMechanic Posted July 16, 2016 Report Posted July 16, 2016 With that kind of power it would need a small box to stay safe. If you can build a sealed box, a slot port is not any harder. Maybe Joe X will see this. He has come up with some of the most straight forward plans I have seen. 91 C350 Centurion conversion ( Four Door One Ton Bronco) 250A Alternator (Second Alternator Coming Soon) G65 AGM Up Front / Two G31 AGM in Back Pioneer 80PRS CT Sounds AT125.2 / CT Sounds 6.5 Strato Pro component Front Stage CT Sounds AT125.2 / Lanzar Pro 8" coax w/compression horn tweeter Rear Fill FSD 5000D 1/2 ohm (SoundQubed 7k Coming Soon) Two HDS315 Four Qubes Each 34hz (Two HDC3.118 and New Box Coming Soon)
Mack187Murder Posted July 16, 2016 Author Report Posted July 16, 2016 With that kind of power it would need a small box to stay safe. If you can build a sealed box, a slot port is not any harder. Maybe Joe X will see this. He has come up with some of the most straight forward plans I have seen. Thanks for an actual answer bro. Its always been my understanding ported/vented is desired for those extra few decibles and booming bass. And sealed desire for tight punchy bass? .
ShadeTreeMechanic Posted July 16, 2016 Report Posted July 16, 2016 With that much power you will lose a lot of box volume to the port. The port will need to be big to keep the velocity within reason. If I had my note book handy I would crunch the numbers for the sealed box sorry. 91 C350 Centurion conversion ( Four Door One Ton Bronco) 250A Alternator (Second Alternator Coming Soon) G65 AGM Up Front / Two G31 AGM in Back Pioneer 80PRS CT Sounds AT125.2 / CT Sounds 6.5 Strato Pro component Front Stage CT Sounds AT125.2 / Lanzar Pro 8" coax w/compression horn tweeter Rear Fill FSD 5000D 1/2 ohm (SoundQubed 7k Coming Soon) Two HDS315 Four Qubes Each 34hz (Two HDC3.118 and New Box Coming Soon)
Mack187Murder Posted July 16, 2016 Author Report Posted July 16, 2016 With that much power you will lose a lot of box volume to the port. The port will need to be big to keep the velocity within reason. If I had my note book handy I would crunch the numbers for the sealed box sorry.Dont be. I guess im not in as big of a rush i thought. . I still have to rewire all my speakers with longer wire for better amp placement and crossover placement.. bokt the cresendo somewhere and order 1.5 " thick mdf. I wanted to built it like a fucking tank. Unless u guys think 1.5 is overkill.I see you lurking broke. What u got for me? .
