xfl15s awful noise
So I got 2 xfl 15 dvc4 ohm subs in a custom built box powered by a borrowed temporary pos spl2600.2 amp it's wired in bridged mode to 4 ohms. They sound awesome at low volume no issues, but when I turn it up and it starts getting down it makes this awful and I mean horribly awful noise like a fart or something but if I turn it down it goes back to sounding great? Is this caused from not enough power I figure it's putting out like 400rms if that but it was just to test them out. Do I have the amp setup wrong or something I'm not sure it's driving me crazy. I'm planning on getting a orion xtr 2500.1 soon so hopefully that amp will fix the issue.
Any help is greatly appreciated
Sounds like the coils bottoming out that's normally a box issue , what kind of box ,
2022 Ford Maverick on 22’s        Skar SK1500.1 on 4 Skar VD-8’s        Mids Sundown Super tweeters, Skar TX 6.5 components on Skar SKM400.4                                                 LC2 for audio control  , XS Power D680 XS Series Extra Battery
Its probably some kind of mechanical issue either with the subs or the box. Could be a loose joint somewhere for example.
Under powering the subs is not going to be the problem.
Builds:
Could it be my truck flexxing? Because it's flexing everything so I'm thinking it might be the truck flapping the subs sound great I've been adjusting it. I need to just take this pos out and order a dd1 and the better amp before I mess em up
the box has some serious issues
it is not made well enough to handle high volume
you might be able to fix this if you find a leaky spot or see if the port wall is moving
  • Who's Online   0 Members, 0 Anonymous, 1262 Guests (See full list)
