80prs help
Sorry don't want to thread jack but don't wont to open another topic and ''pollute?'' the forum so i'll ask a question here
What are the rca's on the left side for on a deh-80prs?
For another amp?? that would be awesome...
If not, is it then possible to use the Rockford RF-HLC high level converter to add another amp? (what about the sound quality??)
Sorry and thanks!
I believe that's an input
250 Mechman Alternator
Sky High Car Audio Big 3
XS Power D3400
Rockford Fosgate 1/0 amp kit
Rockford Fosgate T1500-1bdcp
Rockford Fosgate T400-4
DC Audio Lvl 4 12"
Rockford Fosgate Punch 6x8
Pioneer AVH-P2300DVD
SMD Volt Meter
Jhunt is correct. The pair on the left is for auxillary input 2.
Too bad it ain't a rca output...
Want to add a amp for midbass.
The RF HLC, is that any good and will the prs80 be ok with it? and what about sound quality?
A lot off questions from a noob, sorry
And sorry ToNasty for thread jacking
use sub out for midbass and set the lpf to whatever you need, then use your sub amp's own crossover to set the lpf for your subs.
You mean split the rca's? i'm already splitting them to 2 sub amps... so i'm 1 output too short
run rca's into midbass amp and then pass thru that amp into the sub amp. If the midbass amp has the pass thru set of rca's. Or just get a cock box
XS Power D3400
DC Audio Lvl 4 12"
SMD Volt Meter
I get it.
So a HLC is a no go
Thanks!
why do you want to use a LOC ? im lost ?
