Krupske Posted August 2, 2016 Report Posted August 2, 2016 Sorry don't want to thread jack but don't wont to open another topic and ''pollute?'' the forum so i'll ask a question here What are the rca's on the left side for on a deh-80prs? For another amp?? that would be awesome... If not, is it then possible to use the Rockford RF-HLC high level converter to add another amp? (what about the sound quality??) Sorry and thanks!
Jhunt94 Posted August 2, 2016 Report Posted August 2, 2016 I believe that's an input 2007 Ford F-150 Reg. Cab. Flareside250 Mechman AlternatorSky High Car Audio Big 3 XS Power D3400Rockford Fosgate 1/0 amp kitRockford Fosgate T1500-1bdcpRockford Fosgate T400-4DC Audio Lvl 4 12"Rockford Fosgate Punch 6.5" componentRockford Fosgate Punch 6x8Pioneer AVH-P2300DVDSMD Volt Meter
Krupske Posted August 2, 2016 Report Posted August 2, 2016 I believe that's an input Input for what exactly?
bluethunder Posted August 2, 2016 Report Posted August 2, 2016 Jhunt is correct. The pair on the left is for auxillary input 2.
Krupske Posted August 2, 2016 Report Posted August 2, 2016 Jhunt is correct. The pair on the left is for auxillary input 2. Too bad it ain't a rca output... Want to add a amp for midbass. The RF HLC, is that any good and will the prs80 be ok with it? and what about sound quality? A lot off questions from a noob, sorry And sorry ToNasty for thread jacking
Jessica Posted August 2, 2016 Report Posted August 2, 2016 use sub out for midbass and set the lpf to whatever you need, then use your sub amp's own crossover to set the lpf for your subs. Rest in peace, walled 87 accord build log 03' Corolla build with AA Mayhem inside. My super random youtube channel and terrible camera work. Wiring comparison by CaptainzPlanetz Wire and fuse guide by Guest SyKo13
Krupske Posted August 2, 2016 Report Posted August 2, 2016 use sub out for midbass and set the lpf to whatever you need, then use your sub amp's own crossover to set the lpf for your subs. You mean split the rca's? i'm already splitting them to 2 sub amps... so i'm 1 output too short
Jhunt94 Posted August 2, 2016 Report Posted August 2, 2016 run rca's into midbass amp and then pass thru that amp into the sub amp. If the midbass amp has the pass thru set of rca's. Or just get a cock box 2007 Ford F-150 Reg. Cab. Flareside250 Mechman AlternatorSky High Car Audio Big 3 XS Power D3400Rockford Fosgate 1/0 amp kitRockford Fosgate T1500-1bdcpRockford Fosgate T400-4DC Audio Lvl 4 12"Rockford Fosgate Punch 6.5" componentRockford Fosgate Punch 6x8Pioneer AVH-P2300DVDSMD Volt Meter
Krupske Posted August 2, 2016 Report Posted August 2, 2016 run rca's into midbass amp and then pass thru that amp into the sub amp. If the midbass amp has the pass thru set of rca's. Or just get a cock box I get it. So a HLC is a no go Thanks!
Kyblack76 Posted August 2, 2016 Report Posted August 2, 2016 run rca's into midbass amp and then pass thru that amp into the sub amp. If the midbass amp has the pass thru set of rca's. Or just get a cock box I get it. So a HLC is a no go Thanks! why do you want to use a LOC ? im lost ? SMD SUPER SELLER The Burban Build Blazer Build sold Acura trunk build sold
