HDanielh Posted August 1, 2016 Report Posted August 1, 2016 I am running 2x t1000.4 both bridged to power 4 doors with a PPS4-10, a PP4-X and a PP4-T. The tweeters last like 1 minute if I turn it up. Is there something I can do to protect them from blowing so fast? Is there a more suitable tweeter? I really don't want to go back to separate amps for mids and tweets. I am building this system more for loud that SQ.
MADVIBES Posted August 1, 2016 Report Posted August 1, 2016 audiopipe atx 150. very common design used by atleast 10 companies, I swept this tweeter using LMS and it was very good for the style and price. Its my go too tweeter in a pro set up. plus you can recone for 12 dollars,, winning DB DRAG PSYCHLONE PRO 156.3 30 SECOND AVERAGE FO MAX AT 26HZ LEGAL DASH DRIVER DOOR OPEN 158.0@30 HZ MY BEST SO FAR, HOPEFULLY A 160 COME FEBUARY. 156.9@26hz 158.0@30hz
BMS Posted August 15, 2016 Report Posted August 15, 2016 rule of thumb that a tweeter should be rated at 10-20% of your woofers. assuming that they are the same impedance. now what kind of crossover or capacitor are you using to block the low frequencies.
ShadeTreeMechanic Posted August 15, 2016 Report Posted August 15, 2016 Madvibes, does Audiopipe still make the 150? All I can find is the 145. It wouldn't be a new version of the same thing would it? 91 C350 Centurion conversion ( Four Door One Ton Bronco) 250A Alternator (Second Alternator Coming Soon) G65 AGM Up Front / Two G31 AGM in Back Pioneer 80PRS CT Sounds AT125.2 / CT Sounds 6.5 Strato Pro component Front Stage CT Sounds AT125.2 / Lanzar Pro 8" coax w/compression horn tweeter Rear Fill FSD 5000D 1/2 ohm (SoundQubed 7k Coming Soon) Two HDS315 Four Qubes Each 34hz (Two HDC3.118 and New Box Coming Soon)
MADVIBES Posted August 15, 2016 Report Posted August 15, 2016 I buy them off amazon. I only buy the audiopipe version because its the only all black one with a clear phase plug in the middle. also it has a the screw type neck which makes its easy to install into baffles of up to 3/4" fairly easy. I know they have even a bigger one that says 300 watts but I have never listened to it so I can't speak on its sound quality. I do think however that most PA tweeters are complete pieces of shit that have horible sound q and are truly unlistenable. I have found a combo of PA mids and tweeters that I think are super easy to hook up and need only a cap and minimal eq work. DB DRAG PSYCHLONE PRO 156.3 30 SECOND AVERAGE FO MAX AT 26HZ LEGAL DASH DRIVER DOOR OPEN 158.0@30 HZ MY BEST SO FAR, HOPEFULLY A 160 COME FEBUARY. 156.9@26hz 158.0@30hz
Krupske Posted August 15, 2016 Report Posted August 15, 2016 What kind of crossovers? I think he mentioned he is using the pp4-x crossovers from rockford But these crossovers are rated at max 125watts rms maybe that's the reason he keeps blowing them up??
ShadeTreeMechanic Posted August 15, 2016 Report Posted August 15, 2016 If the problem was blowing up crossovers then I would say its the crossover power rating. The crossover lives and the tweeters die. Probably clipping if not then crossover point too low. 91 C350 Centurion conversion ( Four Door One Ton Bronco) 250A Alternator (Second Alternator Coming Soon) G65 AGM Up Front / Two G31 AGM in Back Pioneer 80PRS CT Sounds AT125.2 / CT Sounds 6.5 Strato Pro component Front Stage CT Sounds AT125.2 / Lanzar Pro 8" coax w/compression horn tweeter Rear Fill FSD 5000D 1/2 ohm (SoundQubed 7k Coming Soon) Two HDS315 Four Qubes Each 34hz (Two HDC3.118 and New Box Coming Soon)
ShadeTreeMechanic Posted August 15, 2016 Report Posted August 15, 2016 Maybe he found the problem by now. Who knows? 91 C350 Centurion conversion ( Four Door One Ton Bronco) 250A Alternator (Second Alternator Coming Soon) G65 AGM Up Front / Two G31 AGM in Back Pioneer 80PRS CT Sounds AT125.2 / CT Sounds 6.5 Strato Pro component Front Stage CT Sounds AT125.2 / Lanzar Pro 8" coax w/compression horn tweeter Rear Fill FSD 5000D 1/2 ohm (SoundQubed 7k Coming Soon) Two HDS315 Four Qubes Each 34hz (Two HDC3.118 and New Box Coming Soon)
MADVIBES Posted August 15, 2016 Report Posted August 15, 2016 I use a 250volt 3.3 uhf cap. the tweeter is a 4 ohm model which will roughly crossover at 12k at 6db per octive. the pa mids I use play up to about 11k before roll off so they blend extremely well for not having an inductor on the midbass. I usually run two midbass for every one tweeter, helps with not having to use resistors in the system. as I can get the speakers efficiencies to match pretty close. DB DRAG PSYCHLONE PRO 156.3 30 SECOND AVERAGE FO MAX AT 26HZ LEGAL DASH DRIVER DOOR OPEN 158.0@30 HZ MY BEST SO FAR, HOPEFULLY A 160 COME FEBUARY. 156.9@26hz 158.0@30hz
