loudest tweeters
HDanielh
Madvibes, does Audiopipe still make the 150? All I can find is the 145. It wouldn't be a new version of the same thing would it?
http://www.audiopipe.com/index.php?route=product/product&path=59_64_88&product_id=168
DB DRAG PSYCHLONE PRO 156.3 30 SECOND AVERAGE FO MAX AT 26HZ
LEGAL DASH DRIVER DOOR OPEN 158.0@30 HZ
MY BEST SO FAR, HOPEFULLY A 160 COME FEBUARY.
156.9@26hz  158.0@30hz
I run a 3.3 on the horn tweeter on my Lanzar coax speakers. At first I thought it would be too high but it works out well.
Pioneer 80PRS
  • 2 months later...
The issue is the power, 50 watt tweet getting well over 100watts.
The tweets have there own built in crossover as well so you could consider doing 2 8ohm versions wired down to 4ohms and keep the gain lower then usual to compensate for having to big of an amp.
More tweets less gain is my suggestion.
t1500bdcp
2 t2d4 15"
1 t600.4
1 t400.2
1 set p1 tweets
get two 8ohm 20 watt resistors wire them in paralell, this will keep the power down
  • Who's Online   0 Members, 0 Anonymous, 1276 Guests (See full list)
