alternator whine, ground loop problem, need help
Try grounding hu to battery. Usually fixes the issue. Also ground amps to frame ground that could also be your issue
On 3/28/2014 at 4:22 PM, KyLar96 said:
Its all about the music anyway..... Do a proper install, something your happy with, Fuck everyone else...... improve in time, where you can..... its not rocket science...
Tiburon build //www.stevemeadedesigns.com/board/topic/174059-97-hyundai-tiburon-build-from-ramming-to-slamming-slow-5k-build/
2000 Mountaineer build http://www.stevemeadedesigns.com/board/topic/186736-2000-mountaineer-build-from-ramming-to-slamming-part-iislow-5k-builddc-audio-americanbassxspowersingerarcaudiostingershcavideo-on-pg7/
2000 Mercury Mountaineer: Electrical:Singer 360 hairpin powdercoated white alt, Big 4 double run 1/0 SHCA OFC, 4 runs 1/0 OFC SHCA, limitless 70ah, HU: Pioneer deh80prs interiors: Skar sk85.4 on sb acoustics neo dome tweeters 2 Mmats sq4100s on 4 silver flute 8s(4ohm) SUB Stage: 3 DC5K [email protected] on 6 ascendant audio mayhem 12s d1.4s fully loaded
What I tried today so far.
Isolated the headunit from the metal dash, ground wire to normal spot on mounting bracket, whine still present, starts around 2800 rpm
used a self tapping screw right into the floor, removed paint to bare metal moved radio ground wire to this screw, whine still present
unplugged sub amp, whine still present
re-connected sub amp, unplugged front amp, no whine
Got home, put radio back in perm, reinstalled all removed parts, ground still to screw in floor
Added a ground wire from mounting screw of front amp (Orion 275SX) to ground distribution block, test drive in a minute
the extra ground wire from the amp chassis to ground did nothing,
I removed the Orion amp ground from the dist. block and removed the trim below the rear window, cleaned the paint off in a spot down to metal and attached the Orion's ground wire directly to the metal, whine seems to have gone away !
Will know for sure tomorrow when I go back to work, long drive
Thanks all will update tomorrow after work.
run a four gauge ground from the battery all the way back. problem solved..
DB DRAG PSYCHLONE PRO 156.3 30 SECOND AVERAGE FO MAX AT 26HZ
LEGAL DASH DRIVER DOOR OPEN 158.0@30 HZ
MY BEST SO FAR, HOPEFULLY A 160 COME FEBUARY.
156.9@26hz  158.0@30hz
I have always done this. I have seen the debate about running a ground wire and using frame as ground. When ever I see people with alt wine issues, it's damn near always, they use frame grounds. I have always ran a ground with my power to the back and never had this problem. Only time I did was when an RCA wire was shot and was bringing in noise to the signal.
  • Soon To Be
  • '04 Ford Escape
  • US Alternator 280A Hairpin
  • D4800 Under the Hood
  • (6) XP3000's in Rear
  • Pioneer DEH-80PRS
  • DD AW6.5 (2) per door
  • *Tweeter Unkown*
  • DD SS4a & C3d
  • (2) SCV4000 @ .5Ohm
  • (2) 15" Sundown Zv5
Watched a video last night where they measured voltage loss ( think that's what it was anyway), using a Newer Nissan Altima with a couple amps in it, they measured at the negative battery terminal using the body as the ground, than using 1-0 cable to the battery and it did better using the car as the ground.
The last time I had any alternator whine was way way back in my 80 Datsun 310GX, alpine shaft type cassette deck with a FAS EQ/booster and 2 door speakers, it was so bad the shop put some kind of filter on it and it was OK after that.
I have had 3 Nissan trucks, all headunits grounded in the same place, my former 87 4x4 had the same PPI 2200 amp I am using now, and a 4 ch. Alpine (3554), various EQ's over the years, JVC dual bands (front and rear), Alpine 11 band, Alpine 3342, Sony Headunit XR-U770, no noise ever.
Than a 94 Pathfinder, Alpine headunit from 94, Cerwin Vega 4 ch amp, Alpine ERG180 EQ, no noise problems
my current 93 hardbody
90 Nissan sentra, Sony Headunit, Alpine 3342 EQ ( different one), PPI 2200 amp, Alpine 3454, than a 3455, than a POS crunch amp, than the ORion 275SX, no noise problems, grounded to the rear fender using a self tapping screw.
No idea why all of a sudden I was getting alternator whine in my 93.
http://www.bcae1.com/images/rca/temporaryrcashieldrepair.html​
Just wired some fuses to a Pioneer DEH P7700mp head unit the other day and sounds like new. Did this to my DEH P6800MP a months back and I just used wire and grounded a speaker wire and it came back just as bad. I done the fuse to a few other head units and they have all worked fine. The only one I had a problem was the 6800 that I only used wire in a rush and now it makes noise. Check to see if it has a pico fuse . This will work.
