Benefits of a 14V or 16V system?
So besides the obvious gains in the power your amp can put out, are there any other big advantages of having a 14V/16V system as apposed to a 12V system?
you get to spend more money!
this lol plus some amps are designed to work at a higher voltage, and some 12v amps have a little more power output at higher voltages. Technically speaking you already have a 14v system, you just have a 12v battery. You use 14v batts for 16v systems and 16v batts for 18v systems.
2007 Ford F-150 Reg. Cab. Flareside
250 Mechman Alternator
Sky High Car Audio Big 3
XS Power D3400
Rockford Fosgate 1/0 amp kit
Rockford Fosgate T1500-1bdcp
Rockford Fosgate T400-4
DC Audio Lvl 4 12"
Rockford Fosgate Punch 6.5" component
Rockford Fosgate Punch 6x8
Pioneer AVH-P2300DVD
SMD Volt Meter
All gear will run significantly cooler also. Boards will be happier and make a ton more power easier.
There are several positives to going up in voltage. We are in the process of switching to a 18v system as I type. I'm stoked to see the change. We will run one alt for the ecu to stay happy (and run our 4 chans, they are not high volt friendly atm, but other boards are coming soon), then the other 3 for the bank/sub amps.
Hoping for 12-16 16v xs cells to be coming soon. We can fit 21, and that will happen. Just not this season. It is what it is.
higher voltage = less amperage for same power. means cooler wire, cooler amps, more efficinet amps, less clipping happier subs
BMW M340 xDrive
Best Scores out of a trunk
154+ windows down, 155+ kick
