NVX JAD 1200.1 + DD1 does not work
1.8 volts might not be enough to make the amp stages saturate. It's like having an 8v output head unit but only turning it up a little bit. Apparently the amp needs a higher input level than most. Get a preamp eq or better head unit to jack the signal up.
Pioneer 80PRS
Swapped to a 4v preout hu same issue.
Just because you swapped head units doesn't mean you're getting four volts out immediately. So many variables
THERE IS NO BUILD LOG!
1998 Chevy Silverado ext cab
Alpine CDA-9887
4 Team Fi 15s
2 Ampere Audio TFE 8.0
2 Ampere Audio 150.4
8 XS Power d3400
6 XS power d680
Stinger
Tsunami Wiring
Sky High
Oh ok I wonder if Tony D has heard of this?
Pioneer 80PRS
