KillerKeller40 Posted August 18, 2016 Report Posted August 18, 2016 Ok so I've seen people run 2 runs of 0 gauge from there battery back to there second batter then two more off the battery to the bass amp ? Why is that ?
KillerKeller40 Posted August 18, 2016 Author Report Posted August 18, 2016 Is it's just for better flow or is it actually increasing voltage ?
ChevyBoy95 Posted August 18, 2016 Report Posted August 18, 2016 The more runs you have, the lesser the resistance, which means less drop due to travel over the wire. It also needs to be there to effectively get the current your amp needs to the amp so it can do its job. Not all set ups need multiple runs, but a lot of the setups on here pull 500-2000a of current, and 1 run of 1/0 or 4 gauge would literally melt under these current draws, not to mention the amount of voltage drop across the wire alone would be massive. Best Score to Date : 160.5 dB Outlaw (47Hz)[4 XM 15's & 2 Taramps Bass 12k's] BL : http://www.stevemeadedesigns.com/board/topic/147800-chevyboy95s-4-15s-7krms-wall-1533-db-on-half-power/YouTube: http://www.youtube.com/hitemwiththeflex/
xpoppadaddyx Posted August 18, 2016 Report Posted August 18, 2016 To prevent voltage drops 2002 Chevy Trailblazer (Build) 2013 Nissan Altima (Build) Poppa's YouTube Channel Poppa's FB Page Poppa's Instagram
Skullz Posted August 18, 2016 Report Posted August 18, 2016 For every run of you add the amount of amperage your able to run without melting the wire from over drawing, so if you run 1/0 from front to back you'll have roughly 300 amps of capacity to play with, but if you need 400 amps of draw then a second run is required to meet the demands of your system. 01 Ford focus ZX3 Pioneer AVH-X491BHS PPI PC 4800.2 Morel Maximo 6.5" x2
KillerKeller40 Posted August 18, 2016 Author Report Posted August 18, 2016 Ok makes sense. So Ima be getting a new Ford Fusion when I get home this deployment. Ima use all sky high 0 gauge. Ima do the big 3. (As soon as I buy the car I'll shop for an alt). Ima leave stock front battery for now. Then drop my XS3400 in the trunk with a twisted sounds 2.8k and my 4 channel Lanzar evolution 4K. I have a massive audio hippo 15 for now. Do you think it would be wise to run multiple runs for me ? In the future want to get another XSd3400 and two sundown x15's
Skullz Posted August 18, 2016 Report Posted August 18, 2016 Absolutely, between the 2 amps your very close to the limit, and the extra run will add enough room for expansion later on. 01 Ford focus ZX3 Pioneer AVH-X491BHS PPI PC 4800.2 Morel Maximo 6.5" x2
ChevyBoy95 Posted August 18, 2016 Report Posted August 18, 2016 Ok makes sense. So Ima be getting a new Ford Fusion when I get home this deployment. Ima use all sky high 0 gauge. Ima do the big 3. (As soon as I buy the car I'll shop for an alt). Ima leave stock front battery for now. Then drop my XS3400 in the trunk with a twisted sounds 2.8k and my 4 channel Lanzar evolution 4K. I have a massive audio hippo 15 for now. Do you think it would be wise to run multiple runs for me ? In the future want to get another XSd3400 and two sundown x15's I personally would run 2 1/0 runs. You will probably be pulling around 400a at max. Play with this, http://www.calculator.net/voltage-drop-calculator.html Best Score to Date : 160.5 dB Outlaw (47Hz)[4 XM 15's & 2 Taramps Bass 12k's] BL : http://www.stevemeadedesigns.com/board/topic/147800-chevyboy95s-4-15s-7krms-wall-1533-db-on-half-power/YouTube: http://www.youtube.com/hitemwiththeflex/
KillerKeller40 Posted August 18, 2016 Author Report Posted August 18, 2016 I know the Lanzar won't be putting anywhere near 4K it's only rated at 500x4 at 4 ohm but I don't it will do that. I got it for free so I'm willing to give it a shot. Now my next questions is fusesand what size. So Ima need to put a fuse on each run going to my second battery. Then a fuse on my two runs to my twisted sound and on my run to my Lanzar. Anymore? I've heard to put two on each run between front and back battery?
Skullz Posted August 18, 2016 Report Posted August 18, 2016 Fuse the wire, 300a fuses will do for each of the runs. 01 Ford focus ZX3 Pioneer AVH-X491BHS PPI PC 4800.2 Morel Maximo 6.5" x2
