Sub/box wiring -- IM SURE THE COMPANY DID THIS WRONG
I paid a company to install this system because I updated the amp and subs--
Amp is JL HD750/1
Subs (2) JL audio w3v3-4.
Notice they have been running hot and jl specs say this should not happen I am thinking it is the wiring job. I made a diagram showing how they wired the subs, box terminals and amp together...
Looks right to me, what ohm load were you trying to accomplish or think is right/wrong? they are SVC
2007 Chevy Tahoe (SOLD)
2 ~ DC Audio 5.0K @0.67
3 ~ DC Audio 5.0K @1.0
1 ~ XS Power D4800
1 ~ XS Power D3400
8 ~ XS Power XP3000
320+ Sq. Ft. Sound Deadener
Pioneer AVH-X5500BHS
http://www.the12volt.com/caraudio/woofer_configurations.asp?Q=1&I=41#results
You're well within the ratings of the amp
http://www.jlaudio.com/hd750-1-car-audio-hd-amplifiers-98220
Do you know how they set gains? maybe clipping is causing things to over heat, subs and amp. maybe not enough air flow to amp? where's it located in vehicle?
1 ~ XS Power D4800
1 ~ XS Power D3400
8 ~ XS Power XP3000
They run hot-- the gain has been set properly with the DD1 - the max volume is 38 as it is tuned to that. When I run the system on 26-29 I can usually smell the wood from the box. The subs cone feel a little warm as well. Everything talked about is connected via 8 gauge wire. Ive been afraid to go above 30 as I fear they will blow. I had a pair before this of same subs but they blew within 4 months.
yeah everything looks fine i would check your gain. well since you say your gain is right then you shouldnt have a problem, subs get warm, some even get HOT. theres electricity running through them so they are bound to retain heat. youd be surprised how hot some subs can get and still be perfectly fine.
Fidelity
Built to Last
Team Sound Asleep
24Runner Build Log: http://www.stevemeadedesigns.com/board/topic/196657-24runner-sleeper-system-lots-of-fi-neo-dd-focal-new-video-w-juicebox-lithium/
2 x 12" Fi BTL N2 / 2 x 12" Fi BTL N3
2 DD M3b
Maxwell 2.7V 3000F Supercapacitors
Pioneer DEH-80prs
Focal P165 V30 components
Rockford Fosgate T-400.4
is it normal to smell wood of the box... how could I remedy this?
is your box ported? put an air freshener in it :)
Fidelity
Built to Last
Team Sound Asleep
2 DD M3b
Pioneer DEH-80prs
The wood smell is most likely because of all the air pumping in and out of the box. Hot coils smell very different. If take it back to the shop, explain your concerns, and ask that they re-dd1 the HU and amp.
Don't let them sell you on another amp, just retune what's already installed.
looks fine to me... maybe just dont play it has loud, jl subs arent made to be pushed to there limits, ... i had the jl hd series amps and yes they run pretty hot... try this turn your system on for 20 min but dont play anything bet it will feel warm and it not playing anything... they just run hot, noting to worry about about the amp
Do you guys think the XD1000/1v2 would be a better amp or is there one you would recommend for the subs that doesnt run hot?
  • Who's Online   0 Members, 0 Anonymous, 998 Guests (See full list)
