Lakeshow94 Posted September 13, 2016 Report Posted September 13, 2016 Is there a certain way set gains if you use something like spotify? I typically always just use a usb for music, but spoitfy seems like a cool option. Is "full volume" on all phones a similar signal strength? Does anyone have input on this? 1999 Lexus GS 300 Pioneer DEH-80PRS Singer 240 Amp (Will be installed later) Northstar Group 31 & 24 Sundown SCV-4000 Rockford T400-4 2 12" CT Sound Meso CT Sounds 6.5 Meso Components CT Sounds Tropo 6.5
3vil Posted September 13, 2016 Report Posted September 13, 2016 (edited) I do know that phones will distort at different levels. Unfortunately, I can't say if the dd1 would even pickup a signal due to low voltage on the headphone out, but it's worth a try. Edited September 13, 2016 by 3vil
Jhunt94 Posted September 13, 2016 Report Posted September 13, 2016 I use Spotify to listen to music. Rockford Fosgate has the 3sixty.3 tracks on there, which you can use with the dd-1. I play over Bluetooth, so I played the track, set my phone on full volume, and set my gains. My gain settings were different from when I was using the cd, but whether or not the signal is 100% clean, I don't know. 2007 Ford F-150 Reg. Cab. Flareside250 Mechman AlternatorSky High Car Audio Big 3 XS Power D3400Rockford Fosgate 1/0 amp kitRockford Fosgate T1500-1bdcpRockford Fosgate T400-4DC Audio Lvl 4 12"Rockford Fosgate Punch 6.5" componentRockford Fosgate Punch 6x8Pioneer AVH-P2300DVDSMD Volt Meter
Farting Larry Posted September 20, 2016 Report Posted September 20, 2016 following.. i tend to use spotify through bluetooth on my g4.. of course its downloaded on the highest quality setting also
Wehan Posted September 20, 2016 Report Posted September 20, 2016 I do know that phones will distort at different levels. Unfortunately, I can't say if the dd1 would even pickup a signal due to low voltage on the headphone out, but it's worth a try. DD-1 picked up my pc sound card just fine (its good at full volume). So I just checked my phone on a track 2, and no signal was registered. Using a Galaxy s6 with known good source tracks.
Lakeshow94 Posted October 5, 2016 Author Report Posted October 5, 2016 I do know that phones will distort at different levels. Unfortunately, I can't say if the dd1 would even pickup a signal due to low voltage on the headphone out, but it's worth a try. Let me rephrase. I want to check if the dd1 will distort while using spotify through bluetooth on my 80prs. So voltage shouldn't be an issue, more of finding where it distorts. I'm going to try jhunts method with the rockford track on spotify. So far I've been running my system on my -5db dd1 disc tune and the subs have been fine. I appreicate the input though. 1999 Lexus GS 300 Pioneer DEH-80PRS Singer 240 Amp (Will be installed later) Northstar Group 31 & 24 Sundown SCV-4000 Rockford T400-4 2 12" CT Sound Meso CT Sounds 6.5 Meso Components CT Sounds Tropo 6.5
