Too good to be true?
get 2 xspower 5100's in the back, big 3 with 1/0 welding cable 975 strand rated at 600v n u'll be fine
06 Envoy
250a ALT
2x 2400 kinetiks
USX65KV1 w/ parallel bridged mosfets 2200rms @ 1ohm @13v powering 1 Orion hcca122
Taramp HD2500 for mid range
4xPioneer 6x9's 2x 1" Pioneer tweets
n get some volt meters for the batts that way u can see where the voltage is at all times, thats often overlooked by noobs like me :)
06 Envoy
250a ALT
2x 2400 kinetiks
The cheap eBay alternator is probably just a parts store one with a smaller pulley. Good luck there.
I've had good luck dealing with Excessive Amperage and I know a few heavy hitters up my way that swear by Ohio Generator.
I know Irraggi used to be talked about on forums and you don't hear the name much anymore (I didn't even realize they were still around), I guess this explains why.
The reason the good brands are 550-600$ is because they're worth it.
That's quite a lot for batteries that might take a shit of my stock alt can't handle my amps...
2 is not a lot for a stock alt for one. Secondly, IF you were going to get 2 batteries instead of an alt, you will be in about the same money as a HO alt which will better serve you.
my point is, I don't know if I want to put money in batts, then have my alt kill them for whatever reason, if my alt dies. I think my best bet is to save up for a ho alt.
just to be different and this sounds funny, but I have 26k watts in my car with a stock alt!
I wont change it cause the little bastard hasnt let me down. Plus I cant fit another alt in my car till i remove the ac compressor
and put there... food for thought.
DB DRAG PSYCHLONE PRO 156.3 30 SECOND AVERAGE FO MAX AT 26HZ
LEGAL DASH DRIVER DOOR OPEN 158.0@30 HZ
MY BEST SO FAR, HOPEFULLY A 160 COME FEBUARY.
156.9@26hz  158.0@30hz
  • Who's Online   0 Members, 0 Anonymous, 970 Guests (See full list)
