Optical signal
06RTCharger
It's considered an optical input
Lol ok simple enough. But whats that mean with amplification? Becuase usually with rca's, if ur headunit puts out 5v signals it helps the amp work easier since its already got some power on the signal vs 2v signal. The amp would have to work harder to produce the same output as the 5v signal right? So will the amp have to work extremely hard becuase there is no volts at all going with the optical input? Thanks again man.
No.
The optical feeds the dsp and the rca outs on the dsp feed the amp,
Usually you can adjust the output voltage on the dsp
No.
But i was trying to do optical out on the dsp also, to the optical input on the amp. Thats possible right?
Sure, if you find an amp with optical in.
Why is it that you want to do that though?
Tuned in for amp with optical input.
Pioneer 80PRS
They exist.
As to why op thinks they would somehow be better I have not a clue.
So in that situation, the amp would have to work really hard to amplify the signal? As compared to a 5v preamped signal.
I just want to try something a lil different than most. And it seems the longer you can keep the signal in digital, the better it "should" sound becuase it wont pick up noise or be affected by other types of wire runs. I know there are lots of variables, but generally speaking, getting it digital all the way to the amp is optimal. The only thing seems to be a precaution with optical toslink canbles is making sure u dont bend it too much or pinch it between two hard surfaces, breaking the inner fibers. Also something about making sure you coordinate ur "word clocks" so that u dont have jitter in the signal from things sending data at different times.
Its a big Learning process for me lol.
  • Who's Online   0 Members, 0 Anonymous, 1962 Guests (See full list)
