maxlink?
Get a Hifonics MLX-100 aka maxxlink.
Vehicle: 1997 S10 Blazer 4dr 4X4
Exterior: Rear End Bagged, Black Grill, Lifted 2"
Amplifiers: Rockford Fosgate T8004 & T10001bd
Batteries: 2 Stinger SPV35, Kinetik HC2400
Electrical: Big 3, DC Power 290amp Alternator w/ MLA at 15.5v
Enclosure: 4.2 ft³ @ 33Hz 84sq.in. of port (20sq.in. per cube)
Headunit: Eclipse CD3200 w/ 80G iPod
Mids/Highs: Rockford T152s (a-pillars), Rockford T162s (doors)
Subwoofers: 1 15" Fi BL Fully Loaded
Wire: All 1/0g Kicker Hyperflex
My YouTube Videos
My Fiberglass A-Pillar Build
My "Seamless" Looking Box Build
My DD1508 T-Line Bandpass Build "Seamless" w/ Acrylic Windows (for '05 TrailBlazer)
My Stealth 8" Fiberglass Build (for '05 TrailBlazer)
My Build For A Friend's '08 Cobalt 15" BL Sealed Off From The Trunk
My feedback/references...
I have one of the old RF bass couplers that I used for my 2 1050s but I'm not sure if it'll work for the para-punch knobs.
Member since 25 Jun 2006
2011 Yukon DenaliCustomLightz 4300K HID RetrofitEsky TailsEsky Third BrakeEsky 22sEsky Appliques
I haven't got to play with the new slim line yet but I think they might be useing CAT 5 terminations now.
I know they use them on the T10001,T20001,T40001 BDs so it wouldn't be possible to use the RFC3215 Bass coupler if the slim line Uses CAT 5 ends.
To big to fit into the holes.
Isobaric - Refers to the practice of coupling two drivers together to make them act as one.
"Giving up doesn't always mean you are weak; sometimes it means that you are strong enough to let go."
Insanity: doing the same thing over and over again and expecting different results.
The Destruction of a person builds character.
What bugs me is I don't understand why RF feels people are't going to run multiple amps when they design certain models.
I assume they DO expect ppl to run multiple amps since they provide the RCA outs to make it easier.
I got the two amps installed tonight but haven't had a chance to play with them much yet.
Posted (edited)
Actually the same RJ-45 cable that was used for my 1050s also works for my T40001.
Edited by mrrairai
RCA outs are common on 80% of amps produced.
Come in real handy if your head unit only has one preamp output.
None the less Let me know how those things do.
I read they are only 67% efficient at 1 ohm around 80% at 2 and 4 ohm.
Enjoy man.
Cool.
Just wanted to update this in case anybody else was trying to do the same thing. I posted the same question on the RF forums last week and got no replies so it still looks like ISO was right by saying that it can't be done (using the RF remote).
I did try running the remote to the first amp but it doesn't affect the rca outs for the second amp. Instead of trying to splice 2 cables together, I just went to plan B - use the sub level control on my EQ (in dash) to achieve basically the same thing as the RCA line level controller, only down side is I have to use buttons to control it instead of a knob - not nearly as convenient. Someday, I'll build separate chambers for the subs and will just run 2 RF remote knobs - or get a bigger amp to replace the 2 1500s as LoudBlazer suggested. <_<
  • Who's Online   0 Members, 0 Anonymous, 751 Guests (See full list)
