ferrules or soldering
Ferrules are typically used when you are putting the wire into a connector like an amp, or a fuse holder that uses a set screw to hold the wire. Not something like a ring terminal that should be crimped or soldered.
In those situations you wouldn't really be soldering your wire into your amp if that is what your asking.
Unless I'm just not understanding on what your wanting to do fully. :unknw:
Solder and heat shrink (preferably adhesive lined heat shrink) for smaller gauge wires, hydraulic crimp (not hammer crimp) for larger wires again using heat shrink.
yes im looking to put the ferrules into fuse holder or amp because the wires are geting messed up and torn apart from the screw of the amp and the fuse holder i'd like to use ferrules but i cant find any for SHCA 1/0 wires at a good price from ebay or any where else so my question is can i just solder that end that goes into the fuse anad do the same to the amp size also ?
the idea of a ferrule is that the screw in the terminal will allow it to compress all of the strands into the ferrule and not just what's below the screw.
In theory crimping creates a better connection than soldering
i dont have a choice :( if i could get them or where to get them at a good price and shipping haizz
You could solder the wire and file off any stray strands, i have had to do that a time or two and works fine, just tighten it a few times after the initial install as the soft solder will conform to the shape, but do not over tighten it as you risk stripping the screw.
01 Ford focus ZX3
Pioneer AVH-X491BHS
PPI PC 4800.2
Morel Maximo 6.5" x2
should i use a special kind of solder? , some say it decrease electricity flow
Conductivity is different than resistance. Measure any metal. Resistance is zero. Lead battery terminals conduct less than zinc. Zero difference in resistance.
Pioneer 80PRS
Solider.
Pioneer 80PRS
Solider.
my 2 cents.
Pioneer 80PRS
  • Who's Online   0 Members, 0 Anonymous, 1047 Guests (See full list)
