Updates look good man! What work do you have to do on a boat?
Also have you come across this?
Easier cleaning ability for white cars with this stuff.
I was looking at that last night. Thought to myself.. "i already have the ultimate wax" so i had mixed feelings and opted not to order it.
I do audio installs on the side to afford my toys as you could see above with the 99 accord. One of my jobs from this past summer was on a 34 persuit in fort lauderdale. I did 4 replacement 7" inch speakers using existing holes and screws in his fiberglass T top. Well in 10ft seas coming back through that hurricane that just hit florida he had an issue with 1 speaker falling half out. So im planning on using these rivets and some lock tite to get him done up all proper.
My old YouTube channel : http://www.youtube.com/user/SwordLords1234?feature=mhee
My old build log : http://www.stevemeadedesigns.com/board/topic/161872-96-accord-b2-sundown-sky-high-dc-power-re-re-build-for-heatwave/page-37
My New Build - http://www.stevemeadedesigns.com/board/topic/207041-2016-mazda-6-sql-build/
2016 Mazda 6 Touring
JL Fix 86 - OEM signal correction
B2 prototype DSP 6to8
B2 Ref63 - 3 way active set
2 B2 Class H quattro's
1 B2 Zero.5R @.5
2 B2 HNv3 12 d2
B2 SLIP40 - Lithium in the trunk
Northstar Group 35 under the hood
100ft 2/0 welding cable
30ft 4ga welding cable
20ft 8ga welding cable
All stinger OFC speaker wire
Soundrive custom RCA's
Tons of attention to detail.... Can it be perfect?
Nice, Its interesting to see the electrical components on a boat.
Some more things appeared at my door step.
About 130 lbs of second skin. 160sq feet of damp pro. 36 sq feet of overkill pro. 90 sq feet of overkill. Some tape. Some speaker pads, some butyl rope, and a few other goodies.
For reference...
Thats a lot of layers. I have TWO of these boxes 0_0
1 B2 Zero.5R @.5
2 B2 HNv3 12 d2
zopOKXP.jpg3 rolls of this..
This knife will be handy :).
I also got some tech flex. :)
Black and gray 2/0, 4ga, and 8ga :)
I plan on every wire being covered. Tech flex and Tesa Tape being my choices.
This box is holding electrical strong enough for a 7k on burps.
Good packing.
Bam...
Resting voltage.
I also got some speaker grill cloth. and some wood threaded inserts.
1 B2 Zero.5R @.5
2 B2 HNv3 12 d2
giving me inspiration to start the mazda 3... also a 2016 ... hatch to be exact but I've been cray with work and no motivation ...
My plan is to leave the stock radio separate using a rf360 type setup and just go direct from source to rf360 then amps... But I haven't spent time looking at where to run wire and stuff yet
Good packing.
Bam...
Resting voltage.
Pioneer Premier P880PRS ll Front Stage: US Acoustics 4060 - Random speakers currently ll Sub Stage: Crescendo BC3500D - 15" Xcon sealed @ 3.28 cubes ll Electrical: - Kinetik HC1800(front) NEW***DieHard P-2(rear)
beaker- I know this sounds like a lot of anime bullshit, but it is true.
Thanks bro! Glad I can be of help. I hope this build log gives you inspiration and ideas. It may take a little bit of time with my busy work schedule but I have extremely high standards for this one.
1 B2 Zero.5R @.5
2 B2 HNv3 12 d2
Holy fuck thats a lot of deadening material.
Thanks bro! Yeah its a ton. Im hoping its enough. Pretty sure it will be. Im planning on making this car rock solid. Im thinking 3 layers on the roof. 1 layer on the floor, and 2 layers on just about anything else I can find.
this is gunna be awesome, i love well thought out builds
Thank you bro! Yeah this fucker is getting expensive and I have put as much thought into it as possible. Its almost time to put my money where my mouth is and start building! I think the first couple things are going to do is 1) start deadening the trunk 2) take out my passenger seat and fab up my board for the JL FIX and my DSP. By then I will have my 12v metalworks custom stuff and Ill be able to figure out my amp and battery rack.
after that I think my next weekend goal will be the headliner and roof deadening.
sometime after that will be all the other BS. Im trying to leave the stock speakers playing as long as possible (so im with out music as little as possible)
1 B2 Zero.5R @.5
2 B2 HNv3 12 d2
  • Who's Online   1 Member, 0 Anonymous, 1575 Guests (See full list)
