2011 crew cab Silverado box
Bailey35
I want to get a custom box built for 2 sundown audio 8's and I already own a 800 watt rms amp. I have raised the seat 2.5 inches so I have roughly a total of 3.2 cubic feet is the biggest I can get before calculating port and sub displacement. With that being said the subs only call for .5 to .75 cubes each so with running 2 id need 1.5 going from sundown recommended specs. My question is will there be any negative effects of using this big of a box? I've read on here that a bigger box with less than recomended power is generally good but it's different for every application and sub. Any input is greatly appreciated. Just for reference I'm running the kx800.1 amp. Thanks everyone
When you put subs in an over-sized box you will get increased cone excursion, which CAN damage the subs. You also CAN get really peaky output and poorer sound quality. Neither is guaranteed to happen, but they are both possibilities.
Builds:
