Need help with sound deadening
Hi i am currently in the middle of doing my first proper big install i will be deadening the whole car at some point in the next month or so but mainly the B pillar at the moment so i can start the wall build.
So first of all i going to be bracing the roof as it has nothing up there to support it from flexing was thinking 18mm birch plywood then expanding foam between the roof and wall box.
My question is do i need to deaden the roof before i add the ply or can i just add the wood straight away.
As for everything behind the B pillar i am looking at using silent coat sound deadener ( would us second skin but don't think it's available in the UK ) what i need to know is what thickness should i use for this and just looking for some help in general.
Many thanks.
Many thanks.
Yes we would recommend using sound deadener on the metal first before walling it off. You are correct we can not send liquids via air (International Orders) so we can't send our liquid Spectrum sound deadening. But if you want our peel and stick American made butyl sheets we can send those to you. Just send us your full shipping info and product list and we will work you up a quote with multiple shipping options, send it to [email protected] . If you want liquid, our closest distributor that stocks liquid Spectrum would be our Singapore dealer, here is there Facebook contact info https://www.facebook.com/SecondSkinSG/?fref=ts
I would put as much as possible
There comes a point where you are just wasting time and money by adding more.
