dsw422 Posted November 14, 2016 Author Report Posted November 14, 2016 These? http://m.homedepot.com/p/SPAX-10-x-3-in-T-Star-Drive-Washer-Wafer-Head-Partial-Thread-Yellow-Zinc-Coated-Screw-65-per-Box-4281020050756/206870588 OR these? http://m.homedepot.com/p/SPAX-10-x-3-in-Philips-Square-Drive-Flat-Head-Full-Thread-Yellow-Zinc-Coated-Multi-Material-Screw-72-per-Box-4101020500756/202041016 2014 Ford Focus SE Sedan Factory Sony 10 Speaker Sound System 1994 Ford Bronco Dual head unit (i kno) Sony door speakers Kenwood Rear Speakers Custom Center console in the works. will house an NVX NSW10" https://m.facebook.com/WinnsCustomCarAudio/
Triticum Agricolam Posted November 14, 2016 Report Posted November 14, 2016 Just found on a different site that people often use sheet metal screws.. I was thinking #10 3inch button head square drive would work... yall agree? I use 2-1/2" #10 sheet metal screws. Either pan or button head, I prefer square drive if I can find them. Never had one break on me yet. The reason I like #10 is that's the largest screw you can get with a head size 3/8" or less. Once the head gets over 3/8" of an inch they don't always fit some baskets well. I prefer square drive since you don't have to worry about the driver slipping out and stabbing through the surround as much. They don't strip out as easily either. No matter what you go with, if you put some wax on the screw before you install it, it makes it a lot easier to screw into the wood. "Nothing prevents people from knowing the truth more than the belief they already know it.""Making bass is easy, making music is the hard part."Builds:
audiofanaticz Posted November 14, 2016 Report Posted November 14, 2016 The screws Steve sells are nice, but you typically have to drill out the basket holes a tad. Since those are out of the option then I say SPAX. Thats what all 4 of my BTLS are handing by in my 6th order bandpass. A hair under 158db when all amps are in it and no issues with them, or any other builds I use them in. They are also what I typically send along with my boxes too.
dsw422 Posted November 14, 2016 Author Report Posted November 14, 2016 Just found on a different site that people often use sheet metal screws.. I was thinking #10 3inch button head square drive would work... yall agree?I use 2-1/2" #10 sheet metal screws. Either pan or button head, I prefer square drive if I can find them. Never had one break on me yet.The reason I like #10 is that's the largest screw you can get with a head size 3/8" or less. Once the head gets over 3/8" of an inch they don't always fit some baskets well. I prefer square drive since you don't have to worry about the driver slipping out and stabbing through the surround as much. They don't strip out as easily either. No matter what you go with, if you put some wax on the screw before you install it, it makes it a lot easier to screw into the wood. What size bit should I use to predrill? 2014 Ford Focus SE Sedan Factory Sony 10 Speaker Sound System 1994 Ford Bronco Dual head unit (i kno) Sony door speakers Kenwood Rear Speakers Custom Center console in the works. will house an NVX NSW10" https://m.facebook.com/WinnsCustomCarAudio/
Triticum Agricolam Posted November 14, 2016 Report Posted November 14, 2016 What size bit should I use to predrill? For #10 screws I use a 1/8" bit. "Nothing prevents people from knowing the truth more than the belief they already know it.""Making bass is easy, making music is the hard part."Builds:
KiKaZz74 Posted November 14, 2016 Report Posted November 14, 2016 Just saying. What steve has are what I deal with everyday. Commercial roofing fasteners. Meant to drill thru steel, rubber, food, rock, sheetrock, etc. I use Firestone and they are a #12 or #14. 1 1/4" up thru 14". Can be found at most supply places that are for contractors. Awesome screws. Do predrill tho. They are big. And they will split the wood. Should never break on you tho. My SPL to SQ Build Log Vehicle:1997 Dodge Dakota Ext Cab 4x4 2009 Dodge Journey SXT5.2L V8 Magnum 3.5L V6 Stock AltEquipment: Headunit- Alpine CDE-147BT Mids/Highs Amp- JL Audio G6600 Class AB 6 Channel Sub Amp- Hifonics BRZ1700.1D @ 2 Ohms Taramps DSP3000.1D Sub- Hertz Hi Energy 12" HX300D SounDrive SDA3 12 Tweeters- Rockford Fosgate Power Series Silk Domes Hertz Hi-Energy Mids- Dayton Audio Reference 4" Full Range Drivers Midbass- Silver Flute 6.5" Hertz Hi-Energy 6.5" Processor- MiniDSP 2x4 RCA- 6 channels of SounDrive HF series Wire- EB Flex 2/0 -Member of Team SounDrive
