ShadeTreeMechanic Posted December 23, 2016 Report Posted December 23, 2016 The cross overs are the same ones used in the meso. I have the tweeter set flat 0db. I think the crossover point is low like 1500hz and lets the tweeter do alot of work. I have to figure out how to post a video.lol Edit: I just found out that the crossover point is 3.5k. 91 C350 Centurion conversion ( Four Door One Ton Bronco) 250A Alternator (Second Alternator Coming Soon) G65 AGM Up Front / Two G31 AGM in Back Pioneer 80PRS CT Sounds AT125.2 / CT Sounds 6.5 Strato Pro component Front Stage CT Sounds AT125.2 / Lanzar Pro 8" coax w/compression horn tweeter Rear Fill FSD 5000D 1/2 ohm (SoundQubed 7k Coming Soon) Two HDS315 Four Qubes Each 34hz (Two HDC3.118 and New Box Coming Soon)
oldsoundguy Posted December 23, 2016 Report Posted December 23, 2016 I tried to take a vid of my sub playing with my phone but I bluetooth my phone to my deck for a demo. As soon as I press the button to take a vid the music shuts off. I dont know how to do it...LOL must be an age thing.... 80prs Arc Audio Xdi 1200.6 (using active crossovers) Freaking awesome amplifier Incriminator IA 10.1 Focal PS 130v 5.25 (doors) 4" Faital pro Neo (kick panels) 3" Faital pro Neo and focal tweets( dash) DC Audio level 3 12" custom box designed by joex built by me AGM front, XS 750SE batteries rear DC 180 alt 99 Toyota Tacoma extra cab http://www.stevemeadedesigns.com/board/topic/179476-my-small-build-turned-into-the-ongoing-build/
moh.vze.com Posted December 23, 2016 Report Posted December 23, 2016 oops I replied to the wrong thread. DC Audio - Singer Alternators - Knukonceptz - XS Power - Hybrid Audio - Rockford Fosgate - Second Skin Audio - SMD - Sundown Audio - Elemental Designs
ShadeTreeMechanic Posted December 28, 2016 Report Posted December 28, 2016 Here is a video I found. This guy is putting a set of CT comps in an F150. He over does it a few times on the goofiness but I guess he has to make a show of it. lol 91 C350 Centurion conversion ( Four Door One Ton Bronco) 250A Alternator (Second Alternator Coming Soon) G65 AGM Up Front / Two G31 AGM in Back Pioneer 80PRS CT Sounds AT125.2 / CT Sounds 6.5 Strato Pro component Front Stage CT Sounds AT125.2 / Lanzar Pro 8" coax w/compression horn tweeter Rear Fill FSD 5000D 1/2 ohm (SoundQubed 7k Coming Soon) Two HDS315 Four Qubes Each 34hz (Two HDC3.118 and New Box Coming Soon)
