Viper 791 Xv Door Lock Problem
what vehicle is it? (year make and model)
might need a 451M, XK01-XK07 or 1700G or 1701G depending on which vehicle
Its an '86 Camry
im not seeing ANY module needed for that vehicle....
I THINK I KNOW WHAT THE PROBLEM IS....since you didnt have power door locks were the ones in there cable driven. if so the actuators wont work. they need to be rod driven.
if thats not the problem i dunno what it is. maybe you dont have a relay hooked up right or something
No relays are hooked up more than likely. The 451m that came with your unit will work fine to power two actuators.
RF T1000-1bdCP and T400-4
Boston Acoustics SPG 555
Kenwood eXcelon 995
i dont believe it comes with a 451m, thats something you usualy have to get separately (i know a lot of dodges need it)...but i wasnt sure if there was a relay or not. hard to tell unless your in there or done so many of them you just know. im not an installer so im not sure on that one
also IF it is cable driver it wont work no matter what...
NoFearX18 said:
trainman0978 said:
I bought the 451m and the locks work great now. BUT sometimes when I arm/disarm, the remote says that it didnt recieve a signal back from the control module (even tho the car does arm/disarm) so if my alarm gets set off, the remote wont alert me that its going off. I dont think it has anything to do with the 451m cuz it did it a few times before I got it.
Any ideas on what this problem is?
That won't have anything to do with your 541m.
Where is the antenna mounted? and is the antenna cord bundled up?
And are you sure it won't page you back after it goes off, even when it doesn't receive the arm page?
Kenwood eXcelon 995
My antenna is mounted at the top of my windshield above my rear view mirror and the cord is not bundled up. Also I set off my alarm today to see if it worked but it didnt page the remote or even say that the shock sensor was triggered.
is there any sort of metalic tint(factory blue) where the antenna is mounted? if so move it below and try again.
Kenwood eXcelon 995
I actually had a 20% strip put on the windshield so that I could hide the antenna cuz it so long. But ive even tryed arming/disarming from inside the car and it still does it sometimes.
