2015 Chevy Sonic/Wall/4 PSI 15's/SA 6K/Active/Arc/CDT/Singer/US Alt/XS
Got the face boards going
(2) layers of 1" birch. I plan on bracing the wall internally, details forthcoming this week
Heres the boards mocked up
IG @walledsonic
Holes cut
Much bracing to come
Showing the layout
Dat veneer
IG @walledsonic
I had that crimper before i got the one I have now. I liked that one ^^^^ a ton better. =(
2007 Chevy Tahoe (SOLD)
2 ~ DC Audio 5.0K @0.67
3 ~ DC Audio 5.0K @1.0
1 ~ XS Power D4800
1 ~ XS Power D3400
8 ~ XS Power XP3000
320+ Sq. Ft. Sound Deadener
Pioneer AVH-X5500BHS
Been working on the wall/face bracing this week. The window bracing doesnt line up perfect with the sub holes, but I can fit this 2x3 in there. I like it offset toward the port a bit since the port walls are only 1 layer thick.
Laying out the cutouts for the top and bottom bracing for the wall
Routed on one side to prevent chuffing.
Here's a pic of the bottom brace in
And the top
IG @walledsonic
All the pieces are predrilled or kreg'd, ready to go
IG @walledsonic
Hardware for the speaker connections came in. A 3' long brass all-thread rod and 50 brass nuts. This gives me ( 8 ) 4" long pieces to mount on the back rear wall of the enclosure.
Since Im limited on alternator power, minimizing voltage drop is a key concern.
IG @walledsonic
Ran across a fusing thread yesterday started by @redfred and realized my long cable run should have a fuse on both ends between the front batt & rear bank.  I only have one in the rear, currently.  So I pulled the underhood setup and started on a new bus bar and fuse block.
Heres the stock fuse block for the ECU, starter/alt, etc that normally connects direct to the battery terminal: my finger is on the starter/alt cable.
Old bus bar (already been used for two different setups) VERSUS the new bus:
IG @walledsonic
I'll preface with 'do not try this at home':
Some careful cuts later:
Im using my router really carefully here:
Getting fitted
IG @walledsonic
The copper distribution block I made today connects:
1) Fused alt/starter
2) Fused ECU
3) Fused front battery
4) Fused rear long cable run
Crimping feels so satisfying now
Heres the block after some fancy cuts.  I forgot to snap a pic of the bar by itself, but you can see the shape of the final product
IG @walledsonic
Left this tab on just cause
Final setup:
I still need to unstack the battery connection lugs in the pic above, but thats all I could finish today.  Thanks for looking!
IG @walledsonic
