2015 Chevy Sonic/Wall/4 PSI 15's/SA 6K/Active/Arc/CDT/Singer/US Alt/XS
The bearing in my Ryobi orbital sander is going out.  Got a new orbital and a detail sander.  This Dewalt has a vacuum attachment, which is wayyy better than using packing tape
Photo op
Stance is great considering the #walllife this car is living
Sanding, painting interior, and staining the face are all up next.  Need to decide on a stain color... I'm considering a walnut for a classic wood finish.
IG @walledsonic
Ready to sand
Done sanding, ready for paint on the inside and stain on the outside.
Buying some stain tomorrow to toy around with the color a bit.  The wood is especially light now that some of the veneer is sanded away.  May have to get two colors and try both before I stain these faces
IG @walledsonic
Got down on some staining last night, after deciding on the PolyStains color "Honey"
First coat.  About to go scuff it and do a second coat...
Also trying to figure out how to get (2) 8's in each door...
Read a post by TaylorFade concerning NON-PA 8" mids.  I ended up buying (4) of these Silver Flutes last night.
https://www.madisoundspeakerstore.com/approx-8-woofers/silver-flute-w20rc38-04-ohm-8-wool-cone/
Gonna run the TS parameters in TermLab and determine how I'm gonna work these into the build.
IG @walledsonic
That stain came out good! Where's the link to the non-PA 8's?
2000 Toyota Solara SEV6, 200 amp alternator, Jensen VX7020, Hifonics American Warrior Taurus X, Hifonics American Warrior Centurion X, JBL Club 6500C, Power Acoustik XP2K-4102, Coustic Power Logic HT-612 in a BP4.
Been productive lately, just havent uploaded pics recently.
Cut some 3/8" aluminum threaded rod and got the hardware ready:
Nuts are also aluminum.  The washers against the wood are steel and the crush washers under the nut are copper.
IG @walledsonic
Ran a new chassis ground for the battery.
Slipped the battery current sensor over the 4/0 cable
Scuff paint
Brass rod, double nutted.
Well taped
I may add a ground strap later, so I left some rod to use for later
IG @walledsonic
Grounded my RCAs.  Noise prevention.
Separately grounded (middle)
IG @walledsonic
Been slowly working on an amp rack for the trunk.
First coat of stain today (matches the wall), a second coat will follow tomorrow.
IG @walledsonic
  • Who's Online   1 Member, 0 Anonymous, 1054 Guests (See full list)
