KenC210 Posted December 5, 2016 Report Posted December 5, 2016 Would using wooden dowel pins be alright to use for a sub woofer box? Has anyone ever used them before or tried using them? Kids Cadi Power Wheel Build2007 Ford Escape Build2012 Toyota Corolla Build 2013 Toyota Tundra
3vil Posted December 5, 2016 Report Posted December 5, 2016 Do you mean little baby dowels for joints, or thick dowels for bracing?
KenC210 Posted December 5, 2016 Author Report Posted December 5, 2016 Small dowel pins as a joint Kids Cadi Power Wheel Build2007 Ford Escape Build2012 Toyota Corolla Build 2013 Toyota Tundra
MrSkippyJ Posted December 5, 2016 Report Posted December 5, 2016 What would the purpose be? F150: Stock 2019 Harley Road Glide: Amp: TM400Xad - 4 channel 400 watt Processor: DSR1 Fairing (Front) 6.5s -MMats PA601cx Lid (Rear) 6x9s - TMS69
KenC210 Posted December 5, 2016 Author Report Posted December 5, 2016 to glue and hold a port with out the use of screw holes to have to cover inside the port Kids Cadi Power Wheel Build2007 Ford Escape Build2012 Toyota Corolla Build 2013 Toyota Tundra
Triticum Agricolam Posted December 5, 2016 Report Posted December 5, 2016 Sure, you could use dowels. Neither dowels or screws are needed to build a sufficiently strong box though, glue alone (when properly used) is more than up to the task. "Nothing prevents people from knowing the truth more than the belief they already know it.""Making bass is easy, making music is the hard part."Builds:
KenC210 Posted December 5, 2016 Author Report Posted December 5, 2016 Sure, you could use dowels. Neither dowels or screws are needed to build a sufficiently strong box though, glue alone (when properly used) is more than up to the task. This is what I figured was curious if anyone has tried them. Kids Cadi Power Wheel Build2007 Ford Escape Build2012 Toyota Corolla Build 2013 Toyota Tundra
