Options for 2014 Taurus sub install off of 1200 RMS.
hzsogood
Bought a 2014 Taurus SEL that has sync/myfordtouch so I'm going to keep everything in the dash factory and run a audiocontrol lc2i.
So the only sub I have now is a sa8, and with a huge ass trunk I don't think it'll be worth it.. sooptions for 1200 RMS 4 cf or less.. It's a big trunk but that doesn't mean I want it full ?
Add another sa8, 2 10s, 2 12s , single 15? Good musical sub(s) I don't need anything crazy , I listen to pretty much every type of music, but of course like the lows. I know I'll get shit for it , but of all the re, DD, DC, sundown,kicker, Rockford, ( and on and on ) setups I've had to me the w7 was one of the best sounding , deepest subs I've heard for all around music. But I'm just not wanting to spend $1000 for one. So the options are open!
Take a look at the subs from ficaraudio.com, Ascendant audio, S S A,...those are my fav' : they are very musical, not just boomy. But you need the right box for sure.
What can you have locally ?
To keep it simple, with 4 cf, maybe you can try to fit a single 15" sub (Fi BL, Fi Q, SSA Icon for examples), or 2 12"s on 1200 watts.
The single 15" solution should be the cheapest.
Good luck.
black BMW X1 2.0 l 192 hp
OEM head unit, Amplifiers :  Audison AP 8.9 with integrated DSP and Ampere Audio 1200.
Focal ES 100 K in front doors, and Dayton RS 180 for midbass under the front seats.
2 SSA DEMONS 10" subs, in a sealed box. SecondSkin Damplifier on front doors, and Luxury Liner Pro for the cargo area.
You could use two 12s or a single 15. Soundqubed HDS3.115 is around $180. I have a pair of the 15s and in 4 cubes each and tuned to 34hz they do a good job on the lows. 1200 watts would be perfect. As with any sub, having the correct box makes all the difference. Someone here should be able to help you with a design once you choose the subs.
Pioneer 80PRS
Sounds good man. I'll have plenty of room for a descent enlosure and will probably have it pushed up and held down somehow right against the rear seat so I have alot of accessable room in the rest of the trunk.
All options welcome, and I guess the sub budget is around $500-600.. obviously a single 12-15 would be probably 1/2 of that, which is nice, but 2 10s or 12s the limit will be in that $500 range.
Thanks again
  • Who's Online   0 Members, 0 Anonymous, 1001 Guests (See full list)
