Is it ok to stream music from apple music?
GorillaFIngeRs
I havent had my subs in recently and I have gotten used to using the apple music app. Normally i only play music from my USB device to avoid clipping. I am curious if it would be safe to play music streamed at the highest quality through LTE. Could this be a probem or is this common practice? I do plug my phone into the USB port so I am not streaming it over bluetooth. If I did want to do it this way and it should be safe what method of amp tuning should I use to avoid clipping my equipment? Thanks for any input.
AQ3500.1
15" Fi SP4
1/0 Knuconceptz Power/Ground
1/0 Sky High Big 3 Upgrade
Pioneer AVH-4200NEX
XS Power D1200 Underhood
Intimidator Gel In Trunk
CES 250A Alternator
Nice. What method did you use to set your gains?
AQ3500.1
15" Fi SP4
Pioneer AVH-4200NEX
CES 250A Alternator
I use a DD-1 to set my gains. Which media should I use to set them is a better question.? Since I'm using my USB port to play allle music should I just set it using my thumb drive. It seems to read it as a file from the phone since it doesn't give you the option to control volume from the phone.
AQ3500.1
15" Fi SP4
Pioneer AVH-4200NEX
CES 250A Alternator
Thanks for putting the video up. Good stuff. I noticed that the black probe on the DD-1 had an alligator clip and was put on the power negative. Does anyone else use theirs this way?
Pioneer 80PRS
Is it the same to play a streamed song over the internet as playing a song that is saved to your phone through USB?
AQ3500.1
15" Fi SP4
Pioneer AVH-4200NEX
CES 250A Alternator
In the aspect of tuning the amp with a dd-1. You can't stream the sample tracks. Therefore you can only put them on your phone and play them direct from your phones memory. Streaming is coming In over 4G so I just want to know if there is a difference.
AQ3500.1
15" Fi SP4
Pioneer AVH-4200NEX
CES 250A Alternator
  • Who's Online   1 Member, 0 Anonymous, 770 Guests (See full list)
