Justin Harris Posted December 30, 2016 Report Posted December 30, 2016 To start off, my system is nothing special. JVC head unit, 4 Kicker 6.5's, HiFonics Zeus 1200 monoblock amp, and I "had" a 12" Infinity Kappa 1200.9w. Bought it new in February. Anyway, I never really broke it in but never ran the gain above half on the amp. It's the 2nd Kappa I've owned (Had the older silver ceramic cone) This last one was the model with gold colored cone. On the way to work the other night I was thrashin some dubstep for a passenger and heard the woofer lose suspension and start wheezing. Upon investigation I realized I had torn a substantial portion of the rubber surround from around the cone, not the basket. Has anybody else had this problem? What is the overall opinion on Infinity's equipment? What other companies have subs that are comparable in quality and price to the Infinity's? Thank you in advance for any responses or other feedback!!
Justin Harris Posted December 30, 2016 Author Report Posted December 30, 2016 I've looked at so many different brands and models of subs that my eyes are crossing haha. I'm mainly looking for suggestions for a worthy replacement in the $150-$200 price range. I'd love to blow $600+ on a monster but it just isn't justifiable. Right now, I'm goin back and forth between the Type-R 2ohm dvc, Rockford P2 or P3 2 ohm dvc, or even the newest model Kappa, but I'm not totally sure. I'm open to other suggestions, as long as it's not Soundstream, Power Acoustik, Audiopipe, Planet audio or any of the other run o the mill crap!
reedal Posted December 30, 2016 Report Posted December 30, 2016 There could be an underlying issue as to why you're tearing the surrounds, other than the quality of the sub. I would say the surround tearing is due to over-excursion. What are the specs of your enclosure? how did you determine the setting of your gain? Under half doesn't mean it's the proper setting, since gain is just a voltage matcher. My google is broken, so what is the RMS ratings of that sub and the amp? SMD Tool Map https://www.stevemeadedesigns.com/board/topic/193176-smd-tool-map-new-november-2014/ Build log https://www.stevemeadedesigns.com/board/topic/197217-reeds-03-tahoe-hat-sqaq-singer-xs-shca-cockbox-80prs/?page=32
Justin Harris Posted December 30, 2016 Author Report Posted December 30, 2016 I'm not totally sure of the volume specs on my enclosure, Its a higher end prefab. It's sealed and I want to say it was either 1.25 or 1.50. The sub is rated at 350W RMS and 1400W Peak, and it has switchable impedance 2 and 4 Ohm. The amp is a HiFonics Zeus ZRX1200.1D. It's rated @ 1200W @ 1 ohm, 600 @ 2 ohms. Everyone I asked before buying it all said the woofer should've been easily able to handle that amps output. I rarely experienced any clipping or anything like that, but I saw one review somewhere and it mentioned the sharp edge on the cone as a potential culprit? I've never had a problem with Infinity's products till now.
SkarredSierra Posted December 30, 2016 Report Posted December 30, 2016 Have you looked at the american bass xfl's or skar audio ddx's? Edit- How did you know you werent clipping?
Justin Harris Posted December 30, 2016 Author Report Posted December 30, 2016 I had looked at the stuff from Skar it looks pretty basic but had good price point, I am a bit wary of anything with foam surrounds though. As far as knowing whether I was clipping or not, I have a buddy who works at a small local audio shop, he helped me do some of the finer tuning and we had tried to make it clip with several different types of music and could only get it to do so at unbearable decibel levels which I never achieved because I do value my eardrums a little. But I'm no expert just a enthusiast.
MrSkippyJ Posted December 30, 2016 Report Posted December 30, 2016 Any reason you didn't just use tones to check for clipping? What makes you wary of foam surrounds? F150: Stock 2019 Harley Road Glide: Amp: TM400Xad - 4 channel 400 watt Processor: DSR1 Fairing (Front) 6.5s -MMats PA601cx Lid (Rear) 6x9s - TMS69
ShadeTreeMechanic Posted December 30, 2016 Report Posted December 30, 2016 I think most of the big monster subs run foam surrounds. Some types of music can be hard on equipment. If you were to run a ported enclosure and tuned it low, you would have so much output that at normal levels the system wouldn't even break a sweat. Maybe even step up to a 15? Soundqubed has the HDS315 for around $180. I am running two of them in 4 cubic feet each and tuned to 34hz. Very musical from 60hz kick drums all the way down to the mid 20hz range. EDIT: You might be able to replace the surround. There are several sellers on ebay that sell surrounds for all kinds of subs. 91 C350 Centurion conversion ( Four Door One Ton Bronco) 250A Alternator (Second Alternator Coming Soon) G65 AGM Up Front / Two G31 AGM in Back Pioneer 80PRS CT Sounds AT125.2 / CT Sounds 6.5 Strato Pro component Front Stage CT Sounds AT125.2 / Lanzar Pro 8" coax w/compression horn tweeter Rear Fill FSD 5000D 1/2 ohm (SoundQubed 7k Coming Soon) Two HDS315 Four Qubes Each 34hz (Two HDC3.118 and New Box Coming Soon)
Justin Harris Posted December 30, 2016 Author Report Posted December 30, 2016 Thanks for all the input guys! I'm not totally sure what route to take yet, but any tips/info is much appreciated.
MrSkippyJ Posted December 30, 2016 Report Posted December 30, 2016 First things first, make sure you know what exactly is causing the problem. won't do you much good to get a new sub just to have the problem still exist. F150: Stock 2019 Harley Road Glide: Amp: TM400Xad - 4 channel 400 watt Processor: DSR1 Fairing (Front) 6.5s -MMats PA601cx Lid (Rear) 6x9s - TMS69
