neuspeedescort Posted January 6, 2017 Report Posted January 6, 2017 if you remove the side section of the port and leave the back side portion. it will still have a port. but without seeing a picture of your box it's all hypothetical.
Triticum Agricolam Posted January 6, 2017 Report Posted January 6, 2017 5 hours ago, Tjwubs34 said: So I actually bought that amp off a guy and found out later it blew a MOSFET and was repaired which he failed to tell me when buying. He did play it on his subs and they were loud so I doubt its the amp.. A local builder said my port length is too long he did the math and it's suppose to be only 13" long not almost 32". So idk what to do honestly. I can try to seal the box better than I did but maybe only being wired to 2 ohm is my prpblem. Super frustrating They amp may very well still put out the proper amount of power, you just need to set you gain right. The local builder who said your port should only be 13" long is wrong. To tune a 4" x 14.5" port to 31 hz in a 4.4 cu ft box the port will need to be around 26" long. A 13" long port will probably tune you closer to 38 Hz. "Nothing prevents people from knowing the truth more than the belief they already know it.""Making bass is easy, making music is the hard part."Builds:
Tjwubs34 Posted January 6, 2017 Author Report Posted January 6, 2017 48 minutes ago, Triticum Agricolam said: They amp may very well still put out the proper amount of power, you just need to set you gain right. The local builder who said your port should only be 13" long is wrong. To tune a 4" x 14.5" port to 31 hz in a 4.4 cu ft box the port will need to be around 26" long. A 13" long port will probably tune you closer to 38 Hz. i contacted soundqubed and they said that it should be fine, there is a burn mark on the board and they said it looks like it only burnt the fiberglass.. So really i think this may be just a power issue.... and i dont think the sub likes 2 ohms.... but what is weird is the kid gave me a gain knob and it has a clip meter and the light blinks at half ohm at 2 ohms.... at quarter gain the sub hardly moves enough to produce small noises.....
ShadeTreeMechanic Posted January 6, 2017 Report Posted January 6, 2017 The light blinks at half ohm at two ohms? 91 C350 Centurion conversion ( Four Door One Ton Bronco) 250A Alternator (Second Alternator Coming Soon) G65 AGM Up Front / Two G31 AGM in Back Pioneer 80PRS CT Sounds AT125.2 / CT Sounds 6.5 Strato Pro component Front Stage CT Sounds AT125.2 / Lanzar Pro 8" coax w/compression horn tweeter Rear Fill FSD 5000D 1/2 ohm (SoundQubed 7k Coming Soon) Two HDS315 Four Qubes Each 34hz (Two HDC3.118 and New Box Coming Soon)
reedal Posted January 7, 2017 Report Posted January 7, 2017 the sub doesn't give a crap what load you wire it to. are you sure you're wiring everything correctly? can you put up some pictures of your sub and amp, to include wiring SMD Tool Map https://www.stevemeadedesigns.com/board/topic/193176-smd-tool-map-new-november-2014/ Build log https://www.stevemeadedesigns.com/board/topic/197217-reeds-03-tahoe-hat-sqaq-singer-xs-shca-cockbox-80prs/?page=32
neuspeedescort Posted January 10, 2017 Report Posted January 10, 2017 On 1/6/2017 at 11:44 PM, reedal said: the sub doesn't give a crap what load you wire it to. are you sure you're wiring everything correctly? can you put up some pictures of your sub and amp, to include wiring correct. however the amp does. (i know you know that) if he got a demo of the amp at 1 ohm and he is wiring it at 2 ohm now. there will be a difference in power output by the amp. thus part of his disappointment.
reedal Posted January 10, 2017 Report Posted January 10, 2017 37 minutes ago, neuspeedescort said: correct. however the amp does. (i know you know that) if he got a demo of the amp at 1 ohm and he is wiring it at 2 ohm now. there will be a difference in power output by the amp. thus part of his disappointment. I was referring to him saying "I don't think the sub likes 2 ohms". I agree that it is likely the issue in expectation vs reality though SMD Tool Map https://www.stevemeadedesigns.com/board/topic/193176-smd-tool-map-new-november-2014/ Build log https://www.stevemeadedesigns.com/board/topic/197217-reeds-03-tahoe-hat-sqaq-singer-xs-shca-cockbox-80prs/?page=32
