Hooah87 Posted January 21, 2017 Report Share Posted January 21, 2017 Does anyone know of a 4 channel amplifer that does about 100x 4 at 2 ohms, has front rear and pass thru low level input and output, but most importantly has the ability to sense the front input and use it for the rear rca input, so if you only have one set coming from head unit. And then be able to use the pass thru output to run to my subwoofer amp. Hope I'm not too confusing. Thanks for the help Link to comment Share on other sites More sharing options...
ShadeTreeMechanic Posted January 21, 2017 Report Share Posted January 21, 2017 CT sounds makes a 125.4 amp that has those features. 91 C350 Centurion conversion ( Four Door One Ton Bronco) 250A Alternator (Second Alternator Coming Soon) G65 AGM Up Front / Two G31 AGM in Back Pioneer 80PRS CT Sounds AT125.2 / CT Sounds 6.5 Strato Pro component Front Stage CT Sounds AT125.2 / Lanzar Pro 8" coax w/compression horn tweeter Rear Fill FSD 5000D 1/2 ohm (SoundQubed 7k Coming Soon) Two HDS315 Four Qubes Each 34hz (Two HDC3.118 and New Box Coming Soon) Link to comment Share on other sites More sharing options...
Hooah87 Posted January 21, 2017 Author Report Share Posted January 21, 2017 I looked it up doesn't do what I asked. Need it to have an output rca , but be able to only need one rca input to run both front and rear Link to comment Share on other sites More sharing options...
bmwking Posted January 21, 2017 Report Share Posted January 21, 2017 3 minutes ago, Hooah87 said: I looked it up doesn't do what I asked. Need it to have an output rca , but be able to only need one rca input to run both front and rear thats what Y adapters are for Link to comment Share on other sites More sharing options...
Hooah87 Posted January 21, 2017 Author Report Share Posted January 21, 2017 Ya but you cut your voltage in half right. They already are only 2 volt preouts ,would be a crappier signal that way Link to comment Share on other sites More sharing options...
ShadeTreeMechanic Posted January 21, 2017 Report Share Posted January 21, 2017 A Y splitter would do the same thing as a pass through on an amp. And no it won't cut the voltage in half, that's why a Cock Box can have 8 or more outputs without a pre amp. 91 C350 Centurion conversion ( Four Door One Ton Bronco) 250A Alternator (Second Alternator Coming Soon) G65 AGM Up Front / Two G31 AGM in Back Pioneer 80PRS CT Sounds AT125.2 / CT Sounds 6.5 Strato Pro component Front Stage CT Sounds AT125.2 / Lanzar Pro 8" coax w/compression horn tweeter Rear Fill FSD 5000D 1/2 ohm (SoundQubed 7k Coming Soon) Two HDS315 Four Qubes Each 34hz (Two HDC3.118 and New Box Coming Soon) Link to comment Share on other sites More sharing options...
Hooah87 Posted January 22, 2017 Author Report Share Posted January 22, 2017 Well that's good to know makes hunting for an amp a lot easier Link to comment Share on other sites More sharing options...
neuspeedescort Posted January 26, 2017 Report Share Posted January 26, 2017 the use of a cock box you can see a few tenths of a volt drop when you get a bunch of rca's out. generally speaking splitting an rca is not going to change anything. Link to comment Share on other sites More sharing options...
boomintahoe Posted January 26, 2017 Report Share Posted January 26, 2017 lol cock box Link to comment Share on other sites More sharing options...
