Fi BL 12v3 enclosure help
Looks good I think. Sound is very underwhelming... pretty bummed at the moment.
http://s1168.photobucket.com/user/mlentz2728/media/New Sub Box Build/44C9C07F-4629-4597-81BA-E554166E30DA_zpslgrdpfbo.jpg.html
AQ3500.1
15" Fi SP4
1/0 Knuconceptz Power/Ground
1/0 Sky High Big 3 Upgrade
Pioneer AVH-4200NEX
XS Power D1200 Underhood
Intimidator Gel In Trunk
CES 250A Alternator
is your sub a dvc 2? I have that same amp, it can definitely move that sub. If anything a bit oversize box would allow the sub to move even more.
so far...
HU- pioneer DEH-P59001B
Amp- crescendo BC2000D
Wire- 1/0 awg welding lead
Electric- Big 3 ^same wire
Subs- 2 Obsidian Audio 12 d4's
Box 4ft^3 ported at 33hz. designed by Ram-Designs
Yup it sure is. I checked my wires that are going to the amp before I even set the sub in the box just to be sure. And I was sitting at a solid 1.0.
I thought for sure this thing would move a ton in a box this size. My subsonic is set to 20hz which I know is low but I just wanted to see if the damn tong would get moving.
Also, I just had dual type r's hooked up to this thing and I was flexing pretty good. I think it's the box. I dunno what else it could be....
AQ3500.1
15" Fi SP4
Pioneer AVH-4200NEX
CES 250A Alternator
What about your gain?
so far...
Gain was set with a DD1 like a year ago. I can def get it retuned just to be sure that's not it but it shouldn't be the problem.
AQ3500.1
15" Fi SP4
Pioneer AVH-4200NEX
CES 250A Alternator
Pioneer head unit. Not sure the model. Never "tuned" my ss or low pass other than by ear.
AQ3500.1
15" Fi SP4
Pioneer AVH-4200NEX
CES 250A Alternator
Do these steps at low/medium volume levels to avoid damaging your speakers.
Turn your subsonic all of the way counter clockwise, turn your low pass all of the way clockwise. Check your head unit's manual for steps on how to set its low pass and high pass filters. Turn them off. Has the output of the sub changed?
Give it a shot here shortly. I'll let you know how it goes
AQ3500.1
15" Fi SP4
Pioneer AVH-4200NEX
CES 250A Alternator
Also, check to make sure the "low" or "sub" setting is set to 0 or higher. If you have to change it, then you will also have to reset your gain. Which pioneer unit do you have?
  • Who's Online   0 Members, 0 Anonymous, 6409 Guests (See full list)
