Small enclosure for Sundown X6.5
Jpshockster
Can someone please help me with my box design?  I built one box with a slot port that was 1" x 4" x 21" long but because of my enclosure size it had to fold back and fourth to get the length.  the box seems to have a lot of port turbulence.  I'm now considering a round port however the spec for the sub recommend  4"^2  at 32hz  using a 3" port consumes too much volume and raises my tuning and using a 2" gives me the desired tuning but is under the suggested 4"^2 by .86"^2  will this cause a windy port?
My outside dimensions are 6" tall x 17.75" wide x 10" deep ( the depth can increase by 1" at the top and 2" at the bottom if absolutely necessary. I am trying to tune around 45hz as this is going into a golf cart with the sub and port firing down. (there will be 1.5" between the bottom of the box and the surface the box sits on)  so 1.5" from port face to surface and .625" from surround to surface.  I am open to suggestions in any direction
Note:  sub and port fire down so they are protected form moisture and people. :)
I squeezed out a little more port area and the measurements seem to work. Its a bit more of a square port idea. This is a rough idea but maybe you can make it work. I also used .5 in wood which makes the difference in this case.
Screenshot%2070_zpsrpnujjdv.pngScreenshot%2071_zpshxae2mrm.pngScreenshot%2072_zps5qprmwak.png
so far...
HU- pioneer DEH-P59001B
Amp- crescendo BC2000D
Wire- 1/0 awg welding lead
Electric- Big 3 ^same wire
Subs- 2 Obsidian Audio 12 d4's
Box 4ft^3 ported at 33hz. designed by Ram-Designs
Thanks for the reply Kam311, I ended up making the box a little deeper and using 2.5" pvc pipe.  .31^3 @ 46.15hz and it sounds much better than my first attempt
Awesome,  I'm glad you didn't give up on it!
so far...
  • Who's Online   0 Members, 0 Anonymous, 2028 Guests (See full list)
