Enclosure program for Mac? Or box help
gmoxley1
Hey guys, finally saved up a little to get some new subs and I have have decided on 2 SA 12's. Now my problem is that I need to build a box and I have a macbook pro and to my knowledge the most reputable enclosure programs are made for Windows and not Mac. If anyone has any suggestions on what to use it would be greatly appreciated. That being said, if anyone is bored and wants to design  a box I will also list, hopefully, all the info needed.
The vehicle will be a 98 blazer,
Max dimensions available
37" wide
17" height
25" deep (still leaves plenty of room between the box and back hatch)
Amp is an SAZ-1200d
I like to listen to alot of rock music but love playing demo songs to get loud and sound good too. I'm thinking tuning in the mid to low 30's
I would like to use all the available width to fit nicely between the wheel wells. Also another side note is I would prefer subs up port back with a single slot in the middle but I am not opposed to aero ports if that would work better (I dont have much experience with aeros)
Thanks everyone/anyone who contributes!
1998 chevy blazer 4 door
stock alt 105a
Battery: Autocraft Gold 75-3
Big Three in Sky High Car Audio 4ga
subs: rockford p2 12's (soon to be sundown SA 12's)
Sundown SAZ-1200d on the subs
Mids and Highs: Infinity kappa 6.5 mid in front doors and tweets in Dash
sae 50.4 for mids and highs
SMD OM-1 on the subs
So here is a suggestion, power: to subs rated, amp subsonic filter to 28Hz, minimum port clearance 4", figure is just an assembly guide:
Thanks JoeX! I have one question. What would be the effects of adding a second baffle to create a flush mount? I would think it wouldn't effect anything as the sub would still be mounted on the same baffle either way.
stock alt 105a
No problem to add a second layer on top, just as you probably know a tight fitting flush mount makes it a little difficult to place / take out the subs.
Sweet! And yeah I've had that experience with a box my friend built. I think I will do a chamfer all around the top baffle to make it a little easier...I hope.
Thanks for all the help!
stock alt 105a
Hey Joe...could I get you to do me a box design as well? I'll pay if it helps motivate you. I started my own thread and there's lots of info available to help you visualize my plan. Thanks for any help you can provide!!!
4 American Bass VFL 8" at 0.5 ohm
Soundstream Tarantula 3000.1D at 0.5 ohm
32 hz ported box designed by Mark at Car Audio Fabrications
XS D1200 secondary with Stinger isolator
  • Who's Online   0 Members, 0 Anonymous, 1204 Guests (See full list)
